It is currently Sun Feb 01, 2026 12:54 pm
PostPosted: Mon Mar 24, 2003 11:01 pm
well i just got my headers and intake for my 82 f-150 ordered. Whith this stuff and running a 400cfm webber pregesive 2bbl carb on it i should be raising the hp by 25%. That means that 4.9L inline 6 should be making about 150hp and 263lbs'. Its going to be awsome! 8)
 Post subject: Why?
PostPosted: Mon Mar 24, 2003 11:29 pm
Why? Its still a ford. Sorry, had to give you the old chevy guy joke. Good improvements. Hope it works well for you.
PostPosted: Tue Mar 25, 2003 9:24 pm
Y
PostPosted: Tue Mar 25, 2003 9:43 pm
oh dont worry youll understand when my mud tire clad baheamoth of a truck rolls over your truck :lol:
 Post subject: catch me if you can
PostPosted: Wed Mar 26, 2003 12:56 am
Hummmm, let me think. big ford + 6cyl., little luv+v8= see ya!!!!!!!! 8)
PostPosted: Wed Mar 26, 2003 12:28 pm
That 4.9 was probably the best engine ford ever made. Great inline 6, but it's still a ford.
PostPosted: Thu Mar 27, 2003 7:39 am
Hey,MEPR,
I get the feeling if you dump money on a fuh..fuh...fuh... ford like that- ya might just want to keep it under your hat. Or tell us your spending it on the luv. :wink:
still want to see your project
later
PostPosted: Fri Mar 28, 2003 12:10 am
Ford or not, inline 6 motors are the most smoothest running engines. With the right setup, they will get up and go!
PostPosted: Fri Mar 28, 2003 12:27 am
I don't know about "Ford or not" but there is something about the sound of a well tuned (even a built) straight six. My mom's rig when I was a little kid was a 51 Chevy pickup and I learned to double clutch and shift a two speed rear in my Dad's 50 cab over deuce and a half. Both of them were powered by a solid old Chevy stovebolt straight six 235. The cab over never complained even pulling six or eight ton of grain or hauling a D2 Cat around. It was still running on all six cylinders even when one piston had a chunk out of the top edge, was missing one ring, and the second was broken. Smoked like a burning oil well, but it didn't miss. The same motor ran solid after just replacing the piston and cutting the groove out of the top of the cylinder wall. Dad still hauls farm machinery around on that truck. The 51 pickup has been parked for the last 20 years, but I bet it would fire right up with fresh gas and an oil change. Actually, that gives me an idea for something to do next time I go visit the folks....
PostPosted: Fri Mar 28, 2003 1:06 am
My girlfriend from years ago, had a late 60's Rambler 4 door that had a inline 6. When she bought it, it was in neglect from the previous owners. After going thru it and fixing stuff and tuning it up, it ran sweet! Sitting at a stop light you couldn't tell it was running. And it had really good power. The 3 speed column shift was a drag.
PostPosted: Fri Mar 28, 2003 1:47 pm
I had a 72 chevy p/u with a straight 6 when I was in high school. I beat that poor motor day after day and it held up. I had to put a clutch in it ever summer though. Stock clutches dont hold up to repeated dumpings. It was the only way I could spin the tire.
PostPosted: Fri Mar 28, 2003 6:43 pm
WHY[/b]
PostPosted: Sun Mar 30, 2003 11:42 pm
why well becouse i need something that easy to get parts for. This thing will be going through hell! 8)
PostPosted: Thu Apr 10, 2003 12:58 pm
some of you dont quite understand the greatness of the 80s fords for off roading. The way the front end end works is its like a solid front axle that has been cut in half and then mounted on bushings to the frame. This provided more suspension flex than a solid axle yet is alot stronger than IFS. That and the 300 straight six is a killer motor.
PostPosted: Wed May 24, 2006 1:50 pm
I would also get a cold air induction system also. They bump the horsepower up about 10 to 15 horses
PostPosted: Wed May 24, 2006 2:20 pm
Dang... 3 year gap in postings here...
PostPosted: Wed May 24, 2006 2:40 pm
Swap Specialist Mod
holy old post batman!!
PostPosted: Thu May 25, 2006 1:06 am
man i killed the truck about 2 years ago and havent even owned it for one year :lol:
PostPosted: Tue May 30, 2006 11:29 pm
Banishment Pending
I guess it just wasn't ment to be then..it was after all a FORD :twisted: :twisted:
Wow, old posts, this one is even before my time :lol: :lol:
PostPosted: Wed May 31, 2006 9:45 pm
yeah well that truck was fun. You know your making power when you break a ford 9" 8)
