It is currently Mon Jun 08, 2026 2:30 pm
 Post subject: Battery?
PostPosted: Sun Aug 27, 2006 9:04 pm
Would an alternator overcharging cause the battery to want to boil over? Also charge light comes off and on or in and out. Checked all grounds and the alternator was a little loose fixed that, things where fine but started all over again after about a 1/2 hr
PostPosted: Sun Aug 27, 2006 10:21 pm
Your voltage regulator might be the problem, but for me I have never had a battery boil over before so I'm not completely sure.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sun Aug 27, 2006 11:45 pm
yep it could very well be the voltage regulator
p.s. be carefull what you hook wires up to on the fuse block
PostPosted: Mon Aug 28, 2006 2:39 pm
I would say regulator is sticking in the full charge positition. Also be careful around that boiling battery. It's basically a bomb, along with all the gasses around it. 8O One spark can ruin your whole LUV. :D
PostPosted: Mon Aug 28, 2006 4:27 pm
It could be the battery itself. You could have a dead cell and the charging system is trying to compensate for it. The other 5 cells are being over charged because of the one dead cell.
Play it safe and get the battery tested.
PostPosted: Mon Aug 28, 2006 6:56 pm
thanks guys :lol: :lol: ..... found my gremlin......RUST. pulled one from my stock , plugged it in and all fixed
PostPosted: Wed Aug 30, 2006 5:32 am
PITA Old Fart
Boy have I ever been there and done that.
And that is exactly why I don't buy cheap alternators, cheap voltage regulators, cheap batteries, or thin flimsy cables with crappy bolt-on terminal ends.
Having one battery blow up in a work truck way out in the middle of nowhere and darn near scare me to tears years ago taught me very well the importance of a good solid reliable charging and electrial circuit.
And any circumstances that nearly cause me to soil my britches tend to get my undivided attention and leave a long lasting impression in my poor old tired memory.
You see...I may be dumb...but I do catch on slow....lol
