It is currently Sun Dec 14, 2025 1:51 am
Post new topic Reply to topic  [ 364 posts ]  Go to page 1, 2, 3, 4, 5 ... 19  Next
 Post subject: motors in! (pic)
PostPosted: Wed Aug 23, 2006 11:41 am
A couple of guys from work helped me get it in. I'll kep updating as I go.
PostPosted: Wed Aug 23, 2006 12:19 pm
Saweet!
I like the color!
PostPosted: Wed Aug 23, 2006 2:40 pm
And so far you have kept the e brake pulley. Good job.
PostPosted: Wed Aug 23, 2006 7:53 pm
todays picture
PostPosted: Wed Aug 23, 2006 10:51 pm
Nice!
I'd like to see your motor mounts from the frame to the block sides, and radiator area/mounting too.
I like that you kept the trans dipstick in place!
What trans are you running?
8)
PostPosted: Wed Aug 23, 2006 11:49 pm
What kinda carb?
Got more pictures of the core support?
PostPosted: Wed Aug 23, 2006 11:51 pm
a Demon for sure
PostPosted: Thu Aug 24, 2006 2:27 am
Swap Specialist Mod
thats a damn clean install there man!
PostPosted: Thu Aug 24, 2006 9:23 am
Ben thats a 650 speed demon by barry grant.
Farmer thanks for the compliment means alot coming from a pro at the v-8 luv .
PostPosted: Thu Aug 24, 2006 9:36 pm
Swap Specialist Mod
lol :D no problem man! its always cool to see another swap come together!
PostPosted: Thu Aug 24, 2006 11:17 pm
8O
PostPosted: Thu Aug 24, 2006 11:18 pm
RPOZ11 wrote:
Nice!
8)
PICS!!!!!!!!!??????????????????????????
PostPosted: Fri Aug 25, 2006 8:02 pm
Lookin really good!!!!! Keep the pics coming!!!
PostPosted: Sun Aug 27, 2006 3:26 am
Nice!!! 8)
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sun Aug 27, 2006 9:02 am
Sorry , RPOZ11 I was in the garage all day tring to finish the rear brakes . All I have left is the front ebrake cable to install and the metric to standard rear brake lines and im finished with the brakes. I'll try to post some current pics tonight .
PostPosted: Sun Aug 27, 2006 11:13 am
Pics of my mount for RPOZ11. The finished product will have a brace to the rear also , It will go in at the muffler shop so as not to block exguast pipe.
PostPosted: Sun Aug 27, 2006 11:20 am
T-350 trans?
PostPosted: Sun Aug 27, 2006 11:31 am
Yes th-350 . A really good friend of mine owns a muffler shop in Seabrook , Texas called S&S muffler (shameless plug) and while it's on the lift Alot of things like trans cooler lines , torque converter bolts and sheild , shifter adjustment , ebrake cable adjustment , finalizeing the motor mounts and ground strap installs will get done . I only have a 100 amp service at my house so I can't run a welder , yet . I still have some things like the alternator wiring , lower radiator hose , electric fan wiring , tach and shift light wiring , driveshaft made , distributor wiring. Hope this helps . The guys on this board got me where I am now , so If I can give a little back i'll do my best.
PostPosted: Sun Aug 27, 2006 3:00 pm
Swap Specialist Mod
is that tranny mount built using the stock piece? that gives me a good idea on how to make the one for ezekiel's truck.
 Post subject: hotrod
PostPosted: Sun Aug 27, 2006 4:08 pm
looking good ......when you get it finished up you need to drove out buy my house and lay some rubber down.lol My street is looking a little bare sense my wife and my hot rods are down.lol
