It is currently Fri Feb 20, 2026 1:27 am
 Post subject: g200 compression
PostPosted: Tue Aug 15, 2006 1:07 pm
Swap Specialist Mod
ok. ive heard from many sources that the truck and the impulse g200s had different compression ratios.
since ive got the impulse motor in my truck, what gives the impulse motor more compression? is it the pistons or the head that give it more compression than a truck motor?
and another question.
whats the differences between the g180 and the g200 head?
PostPosted: Wed Aug 23, 2006 7:00 pm
Id say the pistons.
I think they were 8.2 and 8.9 or something for the EFI.
Theres a few cheap impluses up on eBay at the moment.
Bob.
PostPosted: Wed Aug 23, 2006 9:29 pm
The info I have says 9.2:1 for the Fuel Injected Impulses, and I can't find specific info on the truck motor.
PostPosted: Wed Aug 23, 2006 11:30 pm
Swap Specialist Mod
sweet deal then. i had a guy on isuzupup.com that the truck motors ha dished pistons, and the impulse had flattops.
so being that a rebuilt kit for the g200 is only 210bux, id say im just gonna stick with the 4 banger... lol
PostPosted: Thu Aug 24, 2006 2:10 pm
It makes sense really, the FI motor has spark control and a knock sensor to cut out detonation. On carb motors they can't counteract the effects of varying fuel octane, so a drop in compression lets you pretty much ignore detonation at the expense of a little power.
Hmm, I should check the CR on the 2.3L impulse motor vs the Trooper. Could be they did the same thing, I know the Imp motor has a better flowing head and longer duration cam, so a higher compression ratio wouldn't be a surprise. I know it gave that heavy Trooper enough more kick that even my trusty butt-dyno could clearly feel it.
PostPosted: Thu Aug 24, 2006 9:30 pm
Swap Specialist Mod
well im runnig my carb intake and weber on the impulse motor, so i dont have the knock censor hooked up to do anything. i also used the dist out of my truck motor in the impulse motor, so i dont have any computer stuff to deal with.
did the impulse g200 have a different cam then the truck? im thinkin about using the cam from my old motor for a core to send to delta.
PostPosted: Fri Aug 25, 2006 5:24 pm
I don't know on the G200, but I know for sure on the 4ZD1 the Imp motor has 6 degrees more duration on the cam. Best way to find out would be to go into the forums/bulletin board over at http://www.4x4wire.com and look in the Isuzu forums for JLEMOND. He is a treasure trove of Isuzu parts info. I think he posts over at http://www.planetisuzoo.com too. Most of the other guys there are only up on the 4Z series or V6s, but I bet Jerry would be able to answer that question.
PostPosted: Wed Aug 30, 2006 6:21 am
Damn 800xl...one of these days we are going to have to take up a collection around here to get your fingers gold-plated....lol
You are truly a one-of-a-kind fountain of info on Luv's.
I humbly bow to you abilities sir.
I'm not worthy..I'm not worthy...I'm not worthy...
PostPosted: Wed Aug 30, 2006 11:34 pm
From all the books etc ive got here all the motors from G161Z to 4ZD1 (including 4ZC1 turbo) have the same grind cam and then the 2.6L motor has its own special profile.
But then i dont have books on the G200 and 4ZD1 impluse motors.
Bob.
PostPosted: Wed Aug 30, 2006 11:38 pm
Swap Specialist Mod
mkay.
another question.
am i gonna have any problems putting a g180 head on my g200 block? im not gonna be doing anything to the head other than maybe a cam swap. ill more than likely use the stock impulse g200 cam anyways. ive heard that the water jackets dont line up and stuff like that.
PostPosted: Fri Sep 01, 2006 10:32 am
As far as I know the heads will swap OK and if you are going to have you G200 cam reground...it will be done to your spec's which IMHO would be better than the stock Impulse cam anyway.
If you call them and tell them what you have and what you want...they will produce the cam best suited for your needs pretty cheap...as long as you don't get ask them to do anything too exotic.
PostPosted: Fri Sep 01, 2006 12:51 pm
Swap Specialist Mod
yeah i was thinin about havin my cam done by delta to match one of those crow cams. thing is, i dont wanna go to crazy cuz i dont know anyone other than crow cams that has aftermarket valve springs to match a big cam.
PostPosted: Fri Sep 01, 2006 7:32 pm
What?!
Hes full of rubbish! :P :lol:
PostPosted: Sat Sep 02, 2006 3:42 am
Ooooh...I'm telling!
lmao!
But seriously... you want to use new lifters, pushrods, valve springs, and cam bearings when you put in the new cam...and do a valve lash adjustment or you will be sorry.
You never want to use old parts when you put in a new high performance cam in any engine...because it will create a whole new set of problems later on down the road.
PostPosted: Sat Sep 02, 2006 7:04 am
lmao!
Ummm its a SOHC G seires Isuzu engine, the only bit its actually got that you mention replacing is valve springs.
I think there is a small water passage difference with the G200 to the two smaller motors but its no drama. The G161 head on a G200 is a common swap to boost the comp ratio.
The G200 uses a different timing chain tensioner setup to the G180 even though both motors are the same deck height. No drama here again.
Bolt on fit. Do the cam when you do the head, its near on easier to pull the motor right out so you can get the timing cover all sealed up again properly.
Cheers, Bob.
PostPosted: Sat Sep 02, 2006 3:53 pm
Thanks for the correction...don't know what I was thinking.
See what happens when you are typing a post while talking to a customer on the phone...lol
But anyway...it will fit without too much bother.
And he's right - doing it all with the engine out would be my choice.
PostPosted: Sun Sep 03, 2006 11:09 pm
MEPR wrote:
What?!
Yeah whatever you kilt wearing psycobilly. :twisted: Of course to you that is a compliment.
As for taking up a collection, maybe I should put a paypal link in my sig for donations. :P
PostPosted: Sun Sep 03, 2006 11:47 pm
so would that make you an information whore? :lol:
But anyway, when you drop in a cam its a good idea to replace everything that comes in contact with the cam also. Such as bearings and rockers. Also line boring would be a good idea. As stated before new springs is a must. That then brings up the fact that these engines like to stretch timing chains with high lift cams so you might as well invest in a new timing set...
Then you may as well shave the head for more compression and probly bore the block out and rering it too. Then you will probly also want to give the dog a hair cut as well. Dont question me, cutting the dogs hair is a good idea and will make the LUV run alot better...
PostPosted: Mon Sep 04, 2006 3:12 pm
I prefer to think of myself as an information pimp. I send it out on the street and it comes back to me with some extra. Like this thread, I pimp out the ho, you all pay me back with more info than I started with.
On the G series motors there isn't a lot besides the springs to replace in the valve train, but the timing chain would be a very good plan. If it is old and sloppy the extra stress of a higher lift cam might just push it over the edge. I know I would probably just run the rockers I have, but http://www.rockauto.com did carry them last I checked.
PostPosted: Tue Sep 05, 2006 12:49 am
Id run the ones in it too provided they check out ok.
If the motor has had a hard life its a good idea to check the end of the lash screws in the rocker arms. Ive seen a few of these pretty chewed up on Isuzu motors.
If your timing chain (belt in the case of a 4Z) has broken or come adrift, take care to check the arms for cracks ive seen them busted in half.
Bob.
