It is currently Sun Feb 01, 2026 11:29 am
 Post subject: one headlight dim
PostPosted: Wed Aug 23, 2006 8:11 pm
I just bought a 1979 chevy luv and I am working on it to get it on the road. I am having trouble with the head lights. One is bright an the other is dim. I just replaced both an have the same thing, any ideas ?
Thanks
PostPosted: Wed Aug 23, 2006 8:22 pm
welcomr to the site puckett i have no idea how to help you, but im sure someone here does. by the way where are you located and again welcome to the site.
 Post subject: lights
PostPosted: Wed Aug 23, 2006 11:23 pm
welcome
check the ground wire for that light
 Post subject: head lights
PostPosted: Thu Aug 24, 2006 6:23 am
I am for Halifax, Virginia
Thanks for the advice will try an let you know if it works.
PostPosted: Thu Aug 24, 2006 7:05 am
Yes check the ground to the light un bolt it clean (scuff pad or wire brush) and replace. Hint go to an electrical outlet and ask for a small bottle of De-Ox and use it on the mounting surface when you bolt your connections back down. This stuff was made to keep aluminum wire from corroding and so far i have found nothing better. Another Hint use it on your battery terminals there's nothing better.
PostPosted: Fri Aug 25, 2006 11:14 pm
I had a similar problem with both my headlights a while back after painting the engine compartment I forgot to land a ground wire. After correcting the ground problem my lights worked good as new or good as they possibly could.
 Post subject: dim head lights
PostPosted: Fri Sep 08, 2006 6:22 pm
Thanks alot this took care of the lights problem.
PostPosted: Sat Sep 09, 2006 12:40 pm
Also just for future knowledge if anyone has a similar problem and its not a ground check the fuses for any corrosion. I had some nasty fuses in my truck when I got it and it was doing the same thing.
PostPosted: Sun Oct 08, 2006 7:12 am
Yep--you' re having a grounding issue.
