It is currently Mon Dec 15, 2025 11:31 pm
 Post subject: I think I've had it!!!!
PostPosted: Sat Aug 19, 2006 10:47 pm
Banishment Pending
Well my Luv decided to blow the head...again, this is the third time the head has blow in the 2 years that I've had this truck :evil: :evil: :evil: so this time around I'm calling it quits, I'll replace the head/headgasket on it one more time and then I'll be selling it. I've really have had it with the blowing of heads, and as far as I can tell there was no real reason that it blew this time. So I'm getting ride of the Luv and will be getting either a Trooper or a Toyota pickup
PostPosted: Sat Aug 19, 2006 10:51 pm
say it ain't so...
PostPosted: Sat Aug 19, 2006 11:26 pm
Do we know what you truck looks like? Are there pics posted anywhere?
There must be something causing it to blow. Has the head been resurfaced? Has the block been checked? Thats very strange. :smt102
PostPosted: Sat Aug 19, 2006 11:41 pm
Banishment Pending
Rondog, yes to both accounts
there are a few pics of it on here, Scarlet Red, 4x4, Factory A/C, factory buckets, lifted 4.5", after market 15" rims, 215x75r15 BFG A/T KO's w/ about 5,000mi on them in other words one of the nicer 4x4 Luvs still on the road
PostPosted: Sun Aug 20, 2006 6:55 pm
consider yourself banned... :P :lol:
Just a question, what brand of headgaskets have you been using? And also are you shure your coolant flow is good? 3 times in one year is not right definetly. But these engines are alot tougher than most people think as long as you use quality parts. Only gasketsd that i have found worth anything are either Isuzu gaskets or Victor Rienze/ Dana...
PostPosted: Sun Aug 20, 2006 7:25 pm
If you keep blowing the head gasket after surfacing and new parts CHECK the block to see if it is warped,if it is it to can be resurfaced if you clean all the oil out.I used to do this alot when i worked in a machine shop.
PostPosted: Sun Aug 20, 2006 10:38 pm
Banishment Pending
Coolant flow is good, had the rad checked and it was good. could it be the water pump?? and I guess it could be the head gaskets as well, Felpro's both times( I'll be going with an Isuzu gasket this time around :roll: ) I'm pretty darn sure it's not the block, as I had it checked out the last time it blew the head. The fan cluch is a fixed one and not a thermal, that may have something to do with also (have'nt used the a/c though so I don't know) as far as temp goes it stays around normal except for the longest of hill climbs.
Any way I'm going to start taking things apart this week and get things checked out. I'll order an Isuzu gasket set for it and then put it back together and on the market she goes. I'll be posting an ad here when I'm ready
As far as replacement vehicles go I've narrowed it down to 2 choices, either a 1992-1995 Isuzu Trooper , or a 1990-1995 Toyota 4Runner.
PostPosted: Mon Aug 21, 2006 1:42 pm
Thermostat sticking? Had a coolant flush lately?
PostPosted: Tue Aug 22, 2006 9:38 am
I'll tell you what, I'll be in Phoenix Thursday through Sunday, so if you can have her driveable by then, i'll take her off your hands! :wink:
Timmay
2.3 Liters of Isuzu Glory!!!
PostPosted: Tue Aug 22, 2006 2:35 pm
Banishment Pending
Pup, Short time frame but I'll see what I can do, PM if you want any more info
Final, that was one of my ideas as well, I'll replace it just to be on the safe side.
PostPosted: Tue Aug 22, 2006 8:21 pm
:idea: Rezkid heres a very helpful hint use a screwdriver and open the t-stat a few times because the tend to stick when new and not open until about 250-280 degrees, been there done that. good luck with your head problem.
PostPosted: Wed Aug 23, 2006 12:47 am
Banishment Pending
Tj, thanks I'll try that and see what i come up with. Thanks guys for the help, it's been great
PostPosted: Wed Aug 23, 2006 5:33 pm
Timmy youe should just trade him your Pup. Then i could actually help you with every problem you encounter rather than just start ripping stuff apart and tell you i know what im doing... :lol:
PostPosted: Wed Aug 23, 2006 5:48 pm
I would really really like to, but unfortunately I don't think I could afford the gas to drive it home. :cry:
It would be nice to have a good 4x4 luv in the driveway.
Timmay
PostPosted: Wed Aug 23, 2006 6:16 pm
yeah and the Rez-LUV is a perty good looking one from the pics i have seen...
PostPosted: Wed Aug 23, 2006 9:40 pm
Banishment Pending
Too bad Pup
Thanks Meep, I have tried to keep it pretty good looking
Well, REZ-Luv gets fixed this weekend so we'll see how things go
PostPosted: Tue Aug 29, 2006 4:50 pm
Banishment Pending
Well, Luv getting torn into manllana, went to the Isuzu dealer to pick up a headgasket conversation went something like this:
Parts dude: Hi what can help you with today?
Me: I need a headgasket for a 1980 Chevy Luv
PD: You need to go to our Chevy dealer for that
Me: Umm it has an Isuzu engine in it, G180Z
PD: What did the engine come out of?
Me:(starting to get pissed) It came from the factory stock
PD:(looking at me like I'm nuts) ????
Me: The truck was made by Isuzu
PD: What other vehicles had this engine?
Me: First gen Pickups, Troopers(G200 but they use the same headgasket)
PD:( starts talking to another customer and ignors me) at that I rolled my eyes and said under my breath "last time I get anything for here you jackass"
Moral of story, the Parts Dep. at Tim's Isuzu in Prescott AZ SUCKS BIG HAIRY DONKEY NUTS , fuckin square nut monkey banger :smt013 :smt013 :smt093 :smt097
Anyway, went to the Chevy dealer, and it turn out the they no longer carry the part, and that I have to go after market. So I ended up going to AutoZone and getting a Felpro kit(not my first choice but at least they had it in stock) I'll start tearing things apart tommorow and see what the damage is and then throw the thing back together
 Post subject: Old Stuff
PostPosted: Thu Aug 31, 2006 10:13 am
Luv's with a.c were notorious for blowing head gaskets when they were new. The dealer fixed mine three times in a year and wouldn't do any more after that. The only thing they would do is offer me good trade in value for a full size truck. I took it. About a year later I was driving a 74 Luv with a 350/powerglide with a Ford Comet rear end. It was two inches wider, and was an eight inch. I had too much fun with that truck.
PostPosted: Fri Sep 01, 2006 11:04 am
Banishment Pending
Well got it all button'd up and it's running perty good, replaced the thermo and did a coolant flush, I'll be adding a 12" Perma-Cool fan when i get home, that sould help part of the problem, the other part(rad) I'll have rebuilt by a local rad shop and at the same time I'll have them recore it to a 2 or 3 row for some extra cooling capacity. I'll let you guys know how it goes...I may not end up selling it after all :roll: seems that when it's running I love the thing, and when it craps out on me makes me wish i had bought a Toy :lol:
 Post subject: Re:
PostPosted: Thu Oct 21, 2010 8:56 pm
are you using felpro there not right look at your old one and compar it to a felpro i have pic of it on here look for user PNC i found the right 1.8 gasket
