It is currently Sat Mar 28, 2026 11:00 am
 Post subject: drag racing update
PostPosted: Fri Aug 11, 2006 8:55 pm
Well guys, i havnt been around much this summer but between work and racing i havnt been much of anywhere else.Ive been racing the LUV pretty much every weekend ( I miss the last but will be at it this one). Here are a few pics from my shootout weekend the 22nd and 23rd
http://s88141653.onlinehome.us/gallery/ ... _23_06_020
http://s88141653.onlinehome.us/gallery/ ... _23_06_140
http://s88141653.onlinehome.us/gallery/ ... _23_06_340
http://s88141653.onlinehome.us/gallery/ ... _23_06_341
http://s88141653.onlinehome.us/gallery/ ... _22_06_013
http://s88141653.onlinehome.us/gallery/ ... _22_06_068
http://s88141653.onlinehome.us/gallery/ ... _22_06_168
http://s88141653.onlinehome.us/gallery/ ... _22_06_169
http://s88141653.onlinehome.us/gallery/ ... _22_06_368
http://s88141653.onlinehome.us/gallery/ ... _22_06_512
if you have any ?'s feel free to ask
79 luv drag truck
2 skidoos
2 quads
badass duramax diesel
PostPosted: Fri Aug 11, 2006 9:50 pm
Beautiful truck. What do you have for running gear? Have any pics of the eng.?
PostPosted: Sun Aug 13, 2006 9:42 pm
It is a 406 with a dyno sheet that says it makes 531HP & 511 ft lb of torque. Behind it is a 1.76 powerglide, and in the rear spinning the tires is a Ford 9 inch with 5.13 gears. I have a coupla pics of the motor, i just need to upload them somewhere.
79 luv drag truck
2 skidoos
2 quads
PostPosted: Sun Aug 13, 2006 10:01 pm
Great pics!!! What kinda times are you runnin?
PostPosted: Mon Aug 14, 2006 11:00 am
the truck will run 10:70's-10:80's in good air. average around upper 10.80's, i run 1/8 normally so 6.90's. It went to the motor shop this morning because it ran a 7:13 saturday when it should have been 6:88-6.89. Already found a few problems this morning looking at it in day light so he will work on it today and tommorrow. NExt year though NEW MOTOR TIME. I have aprox. 800-900 passes on this motor. We are looking into building a 427-434 small block next season.
79 luv drag truck
2 skidoos
2 quads
PostPosted: Sat Aug 19, 2006 8:05 pm
well guys......we put in a new coan converter, your really cant beat them to tell you the truth BUT tonight went off the deepend. After 2 1 SECOND SLOW passes, it shut off and i have no oil pressure. So tuesday it is going to the shop for a new motor, just dont know what yet. Basically it will be another SBC on alcohol.Hopfully i can reuse my 406 if it isnt too too damaged.
79 luv drag truck
2 skidoos
2 quads
PostPosted: Mon Aug 21, 2006 4:44 pm
Does that rear spoiler provide any downforce or is it just a cool way to add some weight to the rear of the truck?
Someday... My truck will wrinkle a set of tires like that!
PostPosted: Mon Aug 21, 2006 5:14 pm
The rear wind does add downforce, primarily for the end of the track ( when i actually run 1/4). Yea, i run 7lb's of air in the tires and they hook well when the track is in good shape.
79 luv drag truck
2 skidoos
2 quads
PostPosted: Mon Aug 28, 2006 8:30 pm
well i finally have a positive update on my blown motor....the 406 is good, the crank is good, the rods and pistons are even good. But we are going to 13:1 pistons with new rods now. The carb was sent off friday to be converted to alcohol and the full alcohol system was ordered as well. What broke was the pic that connects the harmonic balancer with the crank, it sheered off and tore up the balancer pretty bad. The heads are world castings iron heads but are in good damn shaoe fir being so old and are gonna be ported and cleaned up with new parts put on. We are not sure on the cam yet, its not huge, so a bigger bump stick will be put in.I will be racing again the weekend after labor day, which will be good ebcause i am going nuts. Once we get the motor together i will have more pics and will have some gm X rods (solid shit) and 10:1 nitrous pistons as back ups.
79 luv drag truck
2 skidoos
2 quads
