It is currently Thu Jun 25, 2026 11:22 pm
PostPosted: Fri Jul 21, 2006 12:54 pm
NEWBI HERE.. I have a few Qs about my 84 pup longbed..
IS the wheel base the same as the S-10s.. reason I ask is that i would like to swap frames due to easyer in V-8/V-6 swap.
has anyone swaped a V8/V6 into these later trucks (84 pup's)
and if so what kit did you use ?.
I know there are a ton of other Qs but off hand I cant remember them
thanks all
PostPosted: Thu Jul 27, 2006 11:01 pm
v8 and v6 conversions have been done. the guys on here mostly have the first gen body style trucks though so you have to improvise off what they have done. I have heard that the swap info is the same. I know the suspension part of the truck is the same between the two body styles.
it seems to me someone over there or here did a s10 frame swap, maybe it was a blazer frame swap. But if you cant handle making a set of motor mounts for a v6 or v8 you're not going to want to do a frame swap like this as it is deffinatly not bolt on. Going to be a bit of fabrication involved to get it to work.
You might have better luck over at this forum as it is for us 2nd genners:
http://www.isuzupup.com/forum/index.php
Bagged 84 Pup
Bagged 53 F100
stock 72 Citroen DS19
PostPosted: Thu Jul 27, 2006 11:20 pm
it was an s-10 blazer swap...
Users browsing this forum: Baidu [Spider] and 33 guests
