It is currently Mon Jun 08, 2026 2:30 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
PostPosted: Sat Jul 08, 2006 11:42 pm
would somebody out there let me know if this will fit my 1980 luv with the original 1.8 4 cyl engine
http://cgi.ebay.com/ebaymotors/Distribu ... 0003818995
i would appreciate some help
of course it hurts you are being screwed by an elephant
PostPosted: Sun Jul 09, 2006 12:01 am
Swap Specialist Mod
yes sir that would be the one right there! all fancy and rebuilt too
PostPosted: Sun Jul 09, 2006 12:04 am
thats what is in mine
PostPosted: Sun Jul 09, 2006 2:31 am
you still need the control module that sits by your coil to go with it though
1980 luv 1.8 finally running!!!...... and then like a moron i sold it :(
got another one!!! 1980 mikado. v8 swap here we come... nope divorce and cross country move happened.
got another one!!! 1980 4x4 mikado sport. rusty beater for now...
PostPosted: Sun Jul 09, 2006 9:13 am
This one has it in it, its self contained
PostPosted: Sun Jul 09, 2006 9:58 am
Not trying to snake Easyhours find, but for info purposes, anybody know if it will fit a 79? Thanks.
PostPosted: Sun Jul 09, 2006 10:02 am
mine is a 79. and was a drop in and go
PostPosted: Sun Jul 09, 2006 10:31 am
thanks ctman. Hey, did you change your logo, or whatever it is called?
PostPosted: Sun Jul 09, 2006 10:48 am
Yes, I get tired of the same thing all the time and change every now and then
PostPosted: Sun Jul 09, 2006 12:17 pm
when i went buy the elect ignition it was already gone but i went to their web site they had another one so i bought inybody intrested go to link and type in isuzu i know they had at least one more
http://search.stores.ebay.com/Fruit-Ridge-
Automotive_isuzu_W0QQfciZQ2d1QQfclZ3QQfsnZFruitQ20RidgeQ20AutomotiveQQfsooZ1QQfsopZ1QQftsZ2QQsaselZ130255704QQsofpZ0
PostPosted: Sun Jul 09, 2006 4:40 pm
how do you wire the self contained ones cus in the article on this site it says you need the module. i have one identicle to the one on ebay. but i was trying to find the module
PostPosted: Sun Jul 09, 2006 6:54 pm
one wire to pos. on coil and the other wire to neg. on coil
PostPosted: Sun Jul 09, 2006 7:54 pm
wich one goes where and do i still use the resister? it's got one black wire and one black wire w/red stripe. i'm guessing the red stripe is posotive?
PostPosted: Sun Jul 09, 2006 9:10 pm
i still used the resister and as for wiring i was told it didn't mater as to wich one went where it just needs a hot and ground to fire
PostPosted: Tue Jul 11, 2006 7:17 pm
O.K., just finished the electronic upgrade.
On the distributor I just took off, one of the wires was black with a red stripe. It was connected to the negative side of the coil. So, when I put the electronic distributor in, I put the wire with the red stripe to the negative side of the coil.
Oops, no start.
I switched the wires, put the red stripe to the positive side of the coil, and 'voila, fired right up. And, I left the resistor in the circuit. Have fun.
PostPosted: Tue Jul 11, 2006 8:25 pm
odd i must of got lucky the first time i hooked it up, but thats good to know
PostPosted: Tue Jul 11, 2006 8:55 pm
That's the kind of luck to have!
Here is a side note for anyone else doing this:
I got the distributor from a guy doing a v8 swap. So, I was able to get the wiring harness from the distributor to the coil, and got the coil as well. It's got a nice connector in the middle, terminal rings at the end, so you don't have to whack anything up. If you can get lucky like this, grab the whole thing. He included the plug and coil wires as well. (thanks, big dogg)That was a good thing, because the original coil wire would not quite fit on the new coil. They are in good shape, so I'm not going to replace them. If they hadn't been in good shape, it would have meant a trip to the auto parts store to finish the job.
I just removed my distributor, removed my coil, put the new ones back in, and was done in about 15 minutes, including swapping the two wires at the coil. Good, easy project.
I'm going to go back and check the timing, but that can wait till this weekend.
PostPosted: Tue Aug 01, 2006 7:07 pm
Well as usual when i do do something on a car nothing goes right i pulled the old distributer out there was two wires connected to the post the wire from the condenser and the red and black wire from the neg. side of the coil
on the new electronic dist. there is a coupling with a red and black and green and black coming if i leave off the condenser i have only the wire coming from the coil is that all i need just the one wire
PostPosted: Tue Aug 01, 2006 11:13 pm
You need to hook two wires up
PostPosted: Wed Aug 02, 2006 8:58 am
okay i need to hook up two wires now one comes from the neg side of the coil where does the other come from
