It is currently Mon Jun 08, 2026 12:00 pm
 Post subject: fuel pressure
PostPosted: Fri Jul 07, 2006 5:52 pm
does the luv have any kind of fuel pressure regulator? mine is burning rich and i've got the glass window in my float bowl and it's full all the way to the top. way obove the line. i just rebuilt the carb and it didn't change a thing.
1980 luv 1.8 finally running!!!...... and then like a moron i sold it :(
got another one!!! 1980 mikado. v8 swap here we come... nope divorce and cross country move happened.
got another one!!! 1980 4x4 mikado sport. rusty beater for now...
PostPosted: Fri Jul 07, 2006 6:34 pm
That round window is off center on that plate. The window should be ABOVE center not below.
Your float could need adjusting. The new parts you put in there might not be the exact same as the old ones.
PostPosted: Sat Jul 08, 2006 1:49 am
the whole side of the bowl is a glass window and it's got a line on it. i have it on the way it came from the factory with the line above center. how do you adjust the float?
PostPosted: Sat Jul 08, 2006 7:55 pm
It should tell you in the rebuild kit instructions.
But inside the float chamber, you have to bend the metal part of the float so it will stop or start the flow of fuel sooner or later depending on what you need.
PostPosted: Sun Jul 09, 2006 7:56 am
:idea: Did you check to see if your float was saturated and sinking causing your flooding problem :roll:
PostPosted: Sun Jul 09, 2006 8:35 am
it floats. it floats all the way to the top. i think i'm gonna try bending it.
PostPosted: Sun Jul 09, 2006 10:14 am
I had that problem when i rebuilt my stock carb many, many years ago. The kit i got was for a different carb but i didn't figure that out until i was half way thru the rebuild. I tried using it anyway and the needle/seat assy was different. I cleaned up the old one and used it to get the truck to work. It wasn't 2 months later that i ponied up for a Weber.
