It is currently Tue May 26, 2026 3:37 am
PostPosted: Wed Jul 05, 2006 3:35 am
i need some interior pieces. i need a glove box both the door and latch set up and the inside of the box itself. i also need a dash pad of some sort. and also all the steering wheel pieces. such as the ign switch (doesnt have to work) and the the blinker mechanism must work though. and all the air vents. my truck is a 76 not sure what else i need just yet. thanks for any help in finding these things
PostPosted: Wed Jul 05, 2006 2:43 pm
Where are you located?
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Wed Jul 05, 2006 6:12 pm
shreveport,la
PostPosted: Thu Jul 06, 2006 5:21 pm
I've got the glove box parts, both side vents, and the turn signal switch. What else do you need?
PostPosted: Fri Jul 07, 2006 12:13 am
speedo cluster and ash tray and a dash pad that i can cover or paint
PostPosted: Fri Jul 07, 2006 2:02 pm
I don't have a dash pad, but I'm pretty sure I've got a speedo cluster and an ash tray. Only problem is that my speedo cluster is the newer style for the 78-80 trucks.
PostPosted: Fri Jul 07, 2006 3:48 pm
none of the gahges have to work as long as it will fit in the same location do u know if it wil?
PostPosted: Fri Jul 07, 2006 3:49 pm
PostPosted: Fri Jul 07, 2006 3:56 pm
That's a very good question
