It is currently Tue May 26, 2026 12:11 am
PostPosted: Sun May 07, 2006 9:54 pm
Any body have the roller cage plans to show a profesional welder i don't weld, ok thanks
PostPosted: Thu May 11, 2006 9:37 pm
Japanese Redneck
just buy a LUV cage kit from Jegs or Chassis Engineering or whoever else sells them. take it to a welder and he can figure out the rest. I'dr recommend a welder that does chassis for a living. you're more likely to get the cage installed to NHRA spec than what just any old welder would do.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Mon May 15, 2006 12:33 pm
just bought a cage on friday for my 76 luv and it cost about $400 for a 12 point cage that sould be alot easier than bending and fitting all the pipes they already come all fabed up and are ready to bolt in. biebrich73 arent you the guy from safford arizona?? if so i know of quite a few really good welders in the area...
joey
 Post subject: roll cage
PostPosted: Mon May 15, 2006 4:06 pm
Just put a jegs 12 pt. in my 75. Wasnt to bad.
 Post subject: i found the roller cage
PostPosted: Sat May 20, 2006 4:21 pm
Thanks i found the roller cage in Jegs.
thanks a lot guys
PostPosted: Tue Jun 20, 2006 6:21 pm
You guys have some completed pics?
2003.5 Mazdaspeed Protege
1987 Mazda RX-7 Turbo II
1980 Chevy Luv 4WD
2005 Honda CRF230
 Post subject: pics
PostPosted: Tue Jun 20, 2006 6:27 pm
I think there is 1 pic of my cage its under Donny Herman in the photo gallery.
PostPosted: Wed Jun 21, 2006 7:01 am
8) You know its a litte un nerving to here a cage or roll bar called a roller bar :lol: :lol: :lol: :wink:
PostPosted: Wed Jun 21, 2006 7:11 am
8O By the way were those cage asy you guys installed mild steel or crome moly as i would like to know the weight of each before i start on LUVs cage as it may be a street trk. but with a 455 Buick and a 4spd i woud feel a litte better at 130+ speeds. 8O
PostPosted: Wed Jun 21, 2006 3:32 pm
The 12 pt I got from jegs is mild steel.I had to go to a chassis shop and have them bend the front down bars.Wasnt to bad to install,it helps that my younger brother is one hell of a welder/fabricator!
PostPosted: Thu Jun 22, 2006 7:00 am
do you know about how much all the tubing weighed :?:
PostPosted: Wed Jun 28, 2006 10:50 pm
Japanese Redneck
moly cages save a lot of weight but the material life cycles faster than mild steel. especially in a hard launching car with a trans brake and ladder bars for 4 link. the shock of launching the car stresses it. I believe you have to change it out completely every few years to keep it in cert.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
