It is currently Fri Mar 20, 2026 7:53 am
 Post subject: g200 clutch size
PostPosted: Wed Jun 14, 2006 5:15 pm
Swap Specialist Mod
mkay, i forgot what size the g200 clutch size is. i keep thinkin its 8.6inches, but im not sure. i was lookin on summit for a new clutch, and they have 9.4in clutches for an isuzu. im thinkin that just for the 4z motor?
but anyways, i just need to know what the size is for when i order my clutch. the stock on i put in 3 months ago is already goin out, so id like to upgrade to a centerforce.
PostPosted: Wed Jun 14, 2006 9:54 pm
9.4" sounds like a 4Z clutch alright. The G180s and G200s post 80 should take the 8.6". Before that it was an 8" except for the 1980 4x4s that got the 8.6". Im not 100% on those figures but im perty shure thats how it breaks down.
PostPosted: Thu Jun 15, 2006 1:12 am
Swap Specialist Mod
well i finally remembered to choose the engine size on the summit thing. the g200 1949cc motor has the 8.594in clutch. the 9.4 is for the 2.6. the 2.3 still uses the 8.6. id like to have a 9.4in clucth in the pup though!!
PostPosted: Thu Jun 15, 2006 4:42 am
yeah i have to use ceramic clutches so i have one that lasts. The last parts store clutch lasted me 30K miles is all :lol:
 Post subject: Re: g200 clutch size
PostPosted: Sat Jun 07, 2008 11:02 pm
do ya'll ever read old post?
I do and I was wondering if I could get
a larger clutch. Or maybe a increased
pressure clutch
PostPosted: Sun Jun 08, 2008 11:26 pm
For what motor?????
Inches, ppfft.
The G200Z and 4ZD1 2.3L are 215mm. It is the same clutch but the flywheels have different mounting bolt patterns to the crank.
The 4ZE1 2.6L is 235mm but it is a totally different shaped flywheel, you can use this Flywheel on the 2L turbo or a 2.3L.
You will not get a bigger clutch to fit, you will need to find an uprated clutch. They are readily available here so i dont see why you would not be able to get one over in the US.
Bob
