It is currently Mon Jun 08, 2026 11:16 am
 Post subject: radiator cap
PostPosted: Fri Jun 02, 2006 9:48 pm
Looking for the correct radiator cap for a stock 1.8L engine with a coolant recovery tank. I replaced the cap that came with the recovery tank with a Stant 16 lb non-vented cap.. The problem I am having is the recovery tank fills up and will not siphon the water back into the radiator when it cools down.
PostPosted: Fri Jun 09, 2006 8:03 am
Another thing I noticed is the radiator still had pressure on it after a few days of sitting idle... Engine was completely cold..
 Post subject: Internal Water leak
PostPosted: Fri Jul 07, 2006 5:33 pm
Found the I have a small internal leak. Talked to a local mechanic and he suggested that I use K&W block sealer. Has anyone used this or any other sealer.
PostPosted: Fri Jul 07, 2006 6:38 pm
Welcome to the site. And sorry, no, I'm not familiar with the stuff.
Sounds to me like it could be a slightly blown head gasket , which I don't think that stuff will fix. It will just keep getting worse.
PostPosted: Fri Jul 07, 2006 6:49 pm
KW block sealer is damn good sealer i have used it allot of times but it will not cure a head gasket problem but it will sure stop block and head problems. Hope this helps and good luck :roll:
PostPosted: Fri Jul 07, 2006 11:39 pm
Thanks for the info... Look's like I've got some work this week....
Users browsing this forum: Bing [Bot] and 37 guests
