It is currently Wed May 27, 2026 7:42 am
PostPosted: Fri Mar 14, 2003 5:46 pm
well, i ran a compression test today and it turned out sorta like i thought it would. results:
cyl 1: 150psi
cyl 2: 150psi
cyl 3: 150psi
cyl 4: 0psi
yep, i gots me a dead 'un!!! so ill be buying rings and re-doing my motor soon as i can afford to do so. thanks guys!!
Josh
PostPosted: Fri Mar 14, 2003 6:20 pm
That would tend to suck the fuel down too. No wonder you were only getting 11MPG and complaining about lack of power. ;)
Maybe you should change your sig here to read 3 banger. 8)
PostPosted: Fri Mar 14, 2003 6:46 pm
Did you squirt oil into the cylinder and check it again? If it still reads 0, you have a stuck or bad valve. If your reading goes up, your rings are bad.
PostPosted: Fri Mar 14, 2003 7:50 pm
i didn't check that but i will...thanks man!!
Josh
PostPosted: Fri Mar 14, 2003 7:51 pm
that better 800? :lol:
PostPosted: Sat Mar 15, 2003 10:43 am
lol - three banger!
PostPosted: Sat Mar 15, 2003 1:07 pm
ya like that? :lol: :roll:
Josh
PostPosted: Sat Mar 15, 2003 6:15 pm
and they say luvs are underpoered to begin whith 8O
PostPosted: Sat Mar 15, 2003 9:05 pm
:lol: yea them Metro stroker motors don't help at all
