It is currently Fri May 08, 2026 10:48 am
 Post subject: Just a little engine...
PostPosted: Fri May 19, 2006 7:13 pm
mmmm,500 inches of displacement and unadulterated JUSTICE! 8) :lol:
PostPosted: Fri May 19, 2006 9:33 pm
looks like that'll drop right into a LUV's engine compartment... not worries there..
PostPosted: Fri May 19, 2006 10:15 pm
looks like a good gas saver :P
that will be cool man hopefully swap turns out well for you
James
PostPosted: Sat May 20, 2006 3:27 am
Well to start im just running a 425. That 500 needs some work where as the 425 was a runner...
PostPosted: Sat May 20, 2006 1:32 pm
425.. 500.. either way that is alotta cubes going into a luv!!
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Sat May 20, 2006 1:50 pm
Caddy motor , eh?
From what I remember, arent they based upon a 5" bore center?
If so, you might run into some front clearance issues at the water pump and front bracketry area if you are thinking of installing that in a LUV.....
72 L.U.V.
427 SBC-700R4
Mustang II front suspension
LUV perf parts manufacturing
My Devotion to Karl :
PostPosted: Sat May 20, 2006 2:12 pm
RPOZ11 wrote:
Caddy motor , eh?
Not if you have a big hammer!!!
''''Bottles are for babies''''
77 luv all original with working factory a/c
50,000 original miles
74 chevy luv 1/8th mile
bracket racer
99 chevy silverado supercharged 425hp daily driver.
PostPosted: Sat May 20, 2006 2:37 pm
8O
I think that one cylinder will make more power than my 1.8 dose! :smt022
Looking for that special LUV.
PostPosted: Sat May 20, 2006 2:43 pm
i wont have any clearance isses with a rear mounted radiator 8)
