It is currently Sat Mar 21, 2026 5:15 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed May 17, 2006 12:53 am
Chavy: You have two choices.
1) You can pull out the trans from under the truck which is very hard, and may not even be possible with a 4x4 truck.
2) You can pull the motor and trans together, and then pull the trans off the motor to rebuild it. Once you've got the trans ready, you put them back together and stick it all back in. This can be MUCH easier than trying to get the trans loose from the motor and out with both of them still in the truck. The bottom of the cab and the trans crossmember get in the way making it really hard to get the trans out.
If you do pull the motor and trans together though, you have a chance to replace a lot of other parts really easy like the rear main seal. If your motor is that recently rebuilt, then it probably does not need much done to it. But, it may be a long time before you have it apart again so if anything needs fixing the best time to do it is when the motor is out and in the open. I'm not say you need to rebuild your motor, but if it needs anything, you might not get another chance to replace stuff this easy.
PostPosted: Wed May 17, 2006 11:01 am
What I said is the motor that is in the truck right now is brand new not rebuilt
Since its a new motor and has low miles on it should be easy to drop the tranny out
dont you guys think so
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Wed May 17, 2006 11:13 am
whether your engine in 100% brand new or not, it would be a whole lot easier to pull th emotor and tranny together, especially since you have a 4x4. There just is not clearance under the turck to move it around and get it out. You could spend quite a bit of time trying to get it out the bottom, or you could get the stuff together and have the engine out in an afternoon and, once your tranny is rebuilt, back in just a quickly.
PostPosted: Wed May 17, 2006 12:26 pm
I don't want to sound like a a$$hole, but with your limited experience I would say this job might be over your head. You may want to leave this up to the pros.
PostPosted: Wed May 17, 2006 2:36 pm
How do you know what my experience is
And if I have trouble my dad has had a Luv since they came out
79 4x4 1.8 liter
PostPosted: Wed May 17, 2006 3:25 pm
Good luck.
PostPosted: Wed May 17, 2006 4:22 pm
drummerforhire wrote:
Good luck.
Could not agree more.
Chavy, I don't want to start a pissing match, but I am a professional mechanic with a ASE master certification, and a degree in automotive and diesel technology, and have made a living for the last 22 years at it. You asked "how do you know what my abilities are", it's a easy answer for me. To be a mechanic you must have basic knowledge of several areas of mechanics. I have looked at several posts of yours and have concluded you do not have a good general knowledge of different aspects of mechanics. When people give you advise you often counter them telling them it is wrong when it is right. Bottom line, don't ask questions if you don't want to hear the answers.
PostPosted: Wed May 17, 2006 4:42 pm
Lets just drop it
So takeing every thing out at once is my best bet what if I have the Luv higher the air
79 4x4 1.8 liter
PostPosted: Wed May 17, 2006 7:08 pm
its going to be alot easier pulling the engine and trans together but no to be rude or anything..... if you cant figure out how to pull the trans and motor out of the truck (even if engine is brand new)lol.... do you think that you will be able to rebuild the trans with any problem.... and even if your dad has been around luvs since they came out dosent mean that hes capable of rebuilding a trans and giving it the same potential that it would from a pro shop... my advice is to pull motor and trans out as one and then take the trans to a trans shop and have them rebuild it with all new parts and pieces
PostPosted: Wed May 17, 2006 7:10 pm
and if you have it higher in the air wont make a difference in missing the cross member and all th other stuff under there. on my truck i had to pull the motor out and then i had to pull the trans out from the top but i also do have a v-8 truck....
PostPosted: Wed May 17, 2006 7:58 pm
I sure as hell am not going to rebuild it Ill probly take them both out I would rather go what with you guys are saying and not make it any harder than it is going to be
79 4x4 1.8 liter
PostPosted: Wed May 17, 2006 9:09 pm
good end of conversation and DO IT. let us know how it turns out.
PostPosted: Wed May 17, 2006 10:11 pm
another thing that sending unit for my temp gage if the guy that put the plug in there seald it with some thing what would be the best way to get it out without messing up the intake
79 4x4 1.8 liter
PostPosted: Wed May 17, 2006 10:17 pm
Something meaning what
A) pipe dope
B) yellow glue
C) locktight
D) none of the above
E) all of the above
F) jisim
G) snot
H) paper
I) cement
J) rubber
K) some of the above
PostPosted: Wed May 17, 2006 10:29 pm
yea its gota be one off those it would not bust free when we tryed to tak it off
79 4x4 1.8 liter
PostPosted: Wed May 17, 2006 10:34 pm
i would use a torch!
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Wed May 17, 2006 10:59 pm
like a litel propain torch
79 4x4 1.8 liter
PostPosted: Wed May 17, 2006 11:21 pm
haha i was half jokin man, i dont know if it would srew up the intake or not, i mean it you can melt it enough to pry then go for it..
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Wed May 17, 2006 11:29 pm
Just soak the sending unit with some penetrating oil and it should come off.
As for removing the tranny, I've down both methods 800xl listed.
When I pulled the tranny out alone, I had to loose my exhaust pipe and really fight with it and to turn it at the right angle to get it out.
I recommend taking the engine and tranny out as one unit. Even though there are more things to do, it will be much easier.
Theres not too much to go wrong, the hardest thing for me was getting all the vacuum lines on right.
PostPosted: Wed May 17, 2006 11:38 pm
he doesnt want to rebuild his brand new motor though... that is the catch
chavy... when you say rebuild do you mean that you dont what to pull the motor apart like peice by peice or you dont want to hassle with all the lines and wiring?!?!?!?
!!!FINALLY!!!
-1977 Luv mikado
Users browsing this forum: No registered users and 1 guest
