It is currently Mon Jun 08, 2026 12:06 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Apr 23, 2006 9:49 pm
chavyluv79 wrote:
ITS THAT PLUNGER THing that controls it thats mest up what its doing the plate is staying to far open to idel I have a ex carb and use that punger
PostPosted: Mon Apr 24, 2006 8:06 am
no I have to get the other carb back from school today
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Tue Apr 25, 2006 12:02 am
mess up
79 4x4 1.8 liter
well that part did not work a 76 carb and a 79 carb are difrent in that part so looks like junk yard
79 4x4 1.8 liter
PostPosted: Tue Apr 25, 2006 8:56 am
i dont know why.... i put a 79 on a 76 and it runs fine and now i have a 78 on the 76 and the 79 is back on mine for now and the are all good to go..... where the problem is in the intake manifold they where didferent but easy fixes to get it working
PostPosted: Tue Apr 25, 2006 3:04 pm
There are some differences in the carbs. The newer ones use a single vacuum diaphram on the choke pull off and the older carbs have two. It doesn't make any difference if you swap carbs, but it means you can't just swap individual parts. Sounds like that is the part we are talking about. If the diaphrams are leaking, you'd have a vac leak on top of the choke not working quite right. I managed to run my 76 with one of them plugged off and it didn't really make much difference, but I don't quite know how the two of them work together. Could be the 79 with only one would run like crap if it isn't working.
Solution? I dunno. Check the short bit of hose on the carb for a leak, and try plugging it off and see if it helps/hurts. You might be able to swap the whole works off the 76 carb and get it hooked up, I'm not sure what else would have to swap with it. If your 76 carb is in good shape, try swapping the whole thing and see what happens. If all else fails, get a weber. :)
PostPosted: Tue Apr 25, 2006 5:22 pm
My 76 does this all of the time, to this day. The needle and seat sticks either open or closed.. sometimes open, sometimes closed. All I do, is take it out, blow the crap out of it, and put it back in, and drive it.
I used to drive it in Memphis in rush hour traffic... man, that was a pain in the ass to pull over on the interstate to do that.
oh, yeah.... :P
True story :lol:
