It is currently Thu Dec 18, 2025 4:18 pm
 Post subject: 1979 longbed
PostPosted: Wed Apr 19, 2006 8:10 am
Well here she is layed out
With the front up
Image\
Back up
Interior in serious need of some dashpads and more help(yes the steering wheel needs to go)
1979 LUV longbed LAYIN FRAME
PostPosted: Wed Apr 19, 2006 8:16 am
It is bagged with 2500 lbs Contitech bags in the front and 2600 lbs Contitech's in the rear. I am running a VIAIR 450 compressor feeding a 5 gallon tank. 4 1/2 inch herion valves, Ekstensive 2 link and two switches. It also has true Buick Park Ave portholes in the fenders and Iron cross motorcycle style mirrors. The wheels are 17 inch Escalade wheels with 205/40's
PostPosted: Wed Apr 19, 2006 1:58 pm
Nice truck. And if it snows, you got chains right there ready. :lol: :D
Sorry.
PostPosted: Wed Apr 19, 2006 4:31 pm
Swap Specialist Mod
HEY!! i think thats uh.... greenchevy94's old truck!! does it have a 2 link in the back thats mounted from the original leaf mounts? damn, it looks sick with those eskies too!!
PostPosted: Wed Apr 19, 2006 7:34 pm
Yes that is Garth's(greenchevy94) old truck. I'm trying to clean it up a little bit. I pulled the tint, changed the wheels, put the switches in a DUB Escalade and I am slowly starting to clean up and redo the interior. Thanks for the love on the Eskies, I think they look a lot better than the moons(even though the moons didn't look bad). I told Garth about them and he told me not to ghetto it up.
PostPosted: Wed Apr 19, 2006 7:50 pm
awesome, have any better pictures?
2002 Lexus RX300
1998 Honda Accord
1977 Chevy Crew Cab Dually
1954 Ford F100
http://www.yvtruckclub.com/forum
PostPosted: Wed Apr 19, 2006 7:55 pm
hell i didnt know he was sellin it. if you dont mind me askin how much did you you give for it?
PostPosted: Thu Apr 20, 2006 6:32 am
We traded. I gave him a 1984 Chevy Shortbed 4 wheel drive with 4in susp lift, 3in body lift and 35's.
PostPosted: Thu Apr 20, 2006 7:54 am
they're both good looking trucks... i like the rims on the LUV
PostPosted: Thu Apr 20, 2006 8:17 am
In h.s. I had an 82 1/2 ton just like that except 2WD and all tan and lowered. (So not really like that one.) I always wanted to have my lowered one and a 4WD lifted to park next to it.
PostPosted: Thu Apr 20, 2006 9:43 am
On the dash. We got a Nissan here call the N13 Pulsar. It was built here so i think it was domestic only to us. It was fitted with the Family II motor with delco 808 efi. The TBI 1.6L and the PFI 1.8L.
In Japan they made the 2 door EXA version fitted with the CA16 and or CA18 motor. They also had the sedan version id say in budget trim and ive also heard of the "langley GT" ive seen one pic and it looks to be the same body as we got. Perhaps you got it, id say you go the exa at least.
Ive pulled a few of theses pulsars to bits. Fixed a few up and sold them on. Ive got one here that i was stripping ot go off for scrap, i measured between the door pillars and it comes up the same measurement within a few mm of the KB luv.
Im going to fit the EFI off one of these Family II motors to the G161Z in the truck. One problem ive got is the speed sensor the Pulsar has and electronic speedo with just a sender on the box to drive the speedo and send a signal to the ECU. My idea was to use the instrument pannel in the luv and its electronic speedo and the tacho. Since i found out about the dash witdths being similar ive decided to have a go at fitting the entire dash. It wont be easy but i want to use the full air-con and heater setup, im going to cut the firewall out of the wreck before it goes off for scrap. Im thining at the moment it will be easier just to gut the truck out and use the whole wiring loom etc out of the donor car that way i get the relays and fuse box etc.
Enough crap, to cut it short, the (N13) Nissan dash is the same width. Heres a Pic.
Its not a good pic but you get the idea.
bob.
PostPosted: Thu Apr 20, 2006 9:45 am
^^^^Oh crap the steering wheel is on the wrong side. lol.
PostPosted: Fri Apr 21, 2006 10:39 am
dont laugh at that $50 Grant 10" 5 1/2" dish chain steering wheel ------I got one!!!!!!!!
PostPosted: Fri Apr 21, 2006 6:47 pm
8O 8O 8O 8O
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Sat Jun 10, 2006 4:12 pm
looks pretty effin hot
silly boys (LUV) trucks are for GIRLS
PostPosted: Sat Jun 10, 2006 4:15 pm
Swap Specialist Mod
to bad he sold it...
PostPosted: Wed Aug 02, 2006 7:58 pm
looks like u got a enw dash whered ya get it?
