It is currently Mon May 25, 2026 10:43 pm
 Post subject: mini spools
PostPosted: Tue Apr 11, 2006 11:07 pm
So, after my big record breaking drag experience, I am thinkin of some things I need to do to the luv before the next drag. This is something I found on ebay. Any thoughts????
http://cgi.ebay.com/ebaymotors/ws/eBayI ... AMEWA%3AIT
PostPosted: Fri Apr 14, 2006 3:36 pm
i ran 1 in a 9" for 2 years .works good eats tires turning thow. :twisted:
fun going side whasss down the road
PostPosted: Sat Apr 15, 2006 5:36 pm
I had a spool in a Nova street car. I didn't care for it, front end trying to plow through the turns, back tires always quirping, dangerous on wet roads. I have a detriot in my Jeep, noisy, but as close to a spool as you can get and still have any street manners. I have limited slip in the power stroke, works good almost seamless. My wifes Trailblazer has g80 locker/ gov-loc also works good. Luv is getting a 31 spline trac-loc style posi. I'm hoping this will put power to both rear wheels.
PostPosted: Mon Apr 17, 2006 8:20 pm
I am just lookin to run it at the track, not on the street so it soounds like I might go ahead and get it!!! THANKS for the info guys!!!!!!
PostPosted: Wed Apr 19, 2006 4:22 pm
Japanese Redneck
damn thats cheap for a mini. I think they go for about 30-40 in a jegs catalog. U turns will turn into 3 pointers, no more wet weather driving, etc and then theres always that feeling that you may pull an axle out if you take a turn too fast. but other than that I've seen them cheap mini spools live on the street for 10 years plus in a 10bolt no less. I'd do it in a weekend warrior but would avoid it if possible in a car that will see any more than just saturday night street duty.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Wed Apr 19, 2006 4:27 pm
Swap Specialist Mod
well since were on the topic of mini spools, i wasa think in about gettin one for a 7.5 gm rear in an olds. what all do you have to do to use the spool in that rear. i kinda figure you just replace the spider gears with the spool, but can you still use the stock carrier? im still perplexed by how im gonna do it.
Users browsing this forum: Google [Bot] and 27 guests
