It is currently Mon Feb 02, 2026 4:38 pm
 Post subject: Core Support
PostPosted: Fri Mar 31, 2006 2:02 am
used to live at Luvtruck.com
Hey all, I have a really simple question. I need a new core support for my truck and I was wondering if they were bolted in or welded in?
Thanks,
Jess
I got my LUV!!!!!!!
 Post subject: Re: Core Support
PostPosted: Sun Apr 02, 2006 1:42 am
Thanks,
Jess
I guess this wasn't that easy of a question? 32 views and no replies?
I got my LUV!!!!!!!
PostPosted: Sun Apr 02, 2006 9:55 am
Are you referring to the part that the sides of the radiator bolt to?
Or the piece above the radiator that the hood bolts to?
Assuming your talking about the framework on the front of the truck that holds the radiator, hood, headlights, etc., that whole front piece is spot welded together and spot welded to the rest of the cab.
However it could be replaced by someone with steel cutting, grinding, and welding abilities.
PostPosted: Sun Apr 02, 2006 12:36 pm
ok thanks that's what I needed to know. I'm missing part of it from when the engine was installed the first time, so I think we're going to have to fabricate a piece to make it work.
I got my LUV!!!!!!!
PostPosted: Mon Apr 03, 2006 10:34 pm
Are you talkin about the piece that is missing in the front of this truck?
They usually cut it out, so its easier to get the motor in, or out. Im sure you can fab up something nice to replace it.
PostPosted: Tue Apr 04, 2006 7:57 pm
yeah that's what I'm talking about. I think that's what we're going to do, hopefully in the next week or two!!
I got my LUV!!!!!!!
PostPosted: Wed Apr 05, 2006 8:17 am
Hey Jess - I finally got the 350 in mine and when I went to the board I noticed you hadn't been posting much anymore. I'm glad to see you're back on and working on your truck again - us ladies have to stick together ya know. Anyway, here's a picture of mine. We just bolted in a piece of steel where the hood hinges used to be to hold everything together and to support the radiator and front grill. Hope this helps!
Martha
Image[/img]
1980 shortbed Luv - 350 40 over, etc. - Like I told my momma, it ain't no fun growing up!
PostPosted: Wed Apr 12, 2006 12:53 am
mjboyd, that motor compartment looks pretty clean!! Good job!!!
PostPosted: Wed Apr 12, 2006 1:41 pm
Hi, I wanted to ask where could I get a new radiator core support for an 81-82 LUV or same body style PUP? I'm going to be replacing the cab on my 82 LUV with a newer, rust free cab and the replacement one I'm looking at buying looks like it will need the radiator core support cut out and replaced. Anyone here on the board have one that's possibly collecting dust as a NOS part or anyone know where to get the piece online? Nothing beats a new part and I'd like to try to go with a support that's new for this good condition cab I'm possibly going to buy. Thanks and I appreciate any replies.
Salvy
1982 Chevy LUV diesel
2.25" stainless exhaust
w/ MagnaFlow performance muffler
PostPosted: Wed Apr 12, 2006 1:53 pm
Thanks, Luvnit. It was a four month process but I'm drivin' it now every day and luvin every minute of it. I'll be posting some newer pics hopefully next week that shows how everything finally turned out. It's really strange to drive because I've gone from my daily driver of a lifted 77 Wagoneer to the luv -
and believe it or not, the Wag gets better mileage than the luv! I've gone from looking down and running over people to looking up to make sure I don't get run over :o)
PostPosted: Fri Apr 14, 2006 7:06 pm
That is definently a big change of vehicles :P Definently get some updated pics!!!
PostPosted: Fri Apr 21, 2006 7:43 am
Can anyone provide any advice on where to get a new radiator core support for an 81-82 LUV/81-87 PUP? Really need to know if I can get one for a possible fix on a cab. Thanks and really appreciate any info.
