It is currently Mon Jun 08, 2026 10:43 am
PostPosted: Sun Apr 09, 2006 7:10 pm
Can anyone tell me if a 73 Luv tailgate will fit a 80 luv? Thanks!
PostPosted: Sun Apr 09, 2006 10:09 pm
No it wont. They are wider then the 80 due to the fact that the tail lights were under the bed and not in the corners.
PostPosted: Sun Apr 09, 2006 11:12 pm
Luvr8 is right, the bed is different on the 73. Unless your 80 has had the bed swapped for an older one, the 73 won't fit. If you have tail lights vertical on either side of the tail gate you need a gate from a 75-80 for it to fit.
PostPosted: Mon Apr 10, 2006 12:38 am
yes the 72,73,74,is wider than the later ones
dangerous-toys4life
75 k-5 2x
94 king cab
