It is currently Sun Jun 07, 2026 2:24 am
PostPosted: Fri Mar 07, 2003 12:37 am
well, i got the carb back on my truck again today and it pulled it's same 'ol $hit again, running for about 35-40 secs after it warmed up and acting like it ran out of gas. the gen light came on to but it always has even when it did run and after it ran for a little while it went off, so i think its normal, just recharging the battery. the only conclusion i can come to is that the fuel pump and/or relay is bad. so tomorrow i will carry my happy @$$ back to the part store and get an aftermarket fuel pump and the wiring to wire it up. anyone know a good circuit to wire it to? i really don't wanna go straight battery because of the risks. ya know, leaving it on, having a wreck and it "fueling the fire" or any other number of things. so anyone got any input to this? :evil: :evil:
thanks,
Gettin Frustrated a.k.a. Josh
 Post subject: fuel pump
PostPosted: Fri Mar 07, 2003 10:38 am
Several companies sell an oil pressure switch that is used for a safety shut off for the electric pumps. Check with Summit or Jegs.
1980 4X4 LUV
PostPosted: Fri Mar 07, 2003 7:36 pm
On an electric fuel pump, an oil pressure switch is money well spent. That sucker WILL pump your tank dry and feed a fire in an accident. One idea is to tap it off the line side (power feeding)of any fuse, and add an aftermarket fuse immediately. Or tap into the power feeding the fuel relay. your wiring diagram may even allow you to delete the relay, and bingo- take that fuse.
or get a used relay from a junk yard- I had to.
g
PostPosted: Fri Mar 07, 2003 8:10 pm
I like my on-off switch, personally... :lol:
PostPosted: Fri Mar 07, 2003 8:14 pm
My on-off switch, for those of you who haven't laughed at me yet.... BTW... this happened because I lost my keys...
PostPosted: Fri Mar 07, 2003 8:44 pm
since we are tlaking of fuel pums... my fuel pump makes a real bad noise when it is runnin, and the thing aint pumpin no gas.... this probably means its junk right? btw.... I GOT MY LUVette STARTED UP TODAY, finally hear dit run :)
PostPosted: Fri Mar 07, 2003 9:04 pm
well, guys, i looked at my fuel pump today and someone already had the aftermarket fuel pump i wanted on there, they just had it wired up wrong!! so i fixed the wiring and now she runs like a champ!!!
PostPosted: Fri Mar 07, 2003 9:25 pm
Hey 4x4 :lol: ,
I have an aftermarket pump- makes a huge buzzing! i thought it would bug me until I realized the noisier the better. Fire off my bad v8 and that buzz is dwarfed by everything else. just adds to the package.
HERE I COME!
On that note- anyone else have people roll up windows when you pull up to a light!? :twisted:
g
PostPosted: Fri Mar 07, 2003 10:27 pm
people roll them up, but only becuase i have a pa speaker hooke dup to my radio, and i play classic country out of it
PostPosted: Fri Mar 07, 2003 11:00 pm
you are a evil evil man :x
:lol: :wink: j/k bro
PostPosted: Sat Mar 08, 2003 8:43 am
LARP-
your loosing it man, this is a luv sight, not a ........cavalier?!? sight.
Pink- dude, you must have an infection :!: :lol:
g
PostPosted: Sat Mar 08, 2003 10:30 am
(77ssluv) wrote:
LARP-
g
i swapped my sigs last night...just to see how long it would take someone to notice.....and you are the winner here. :D
*Larp gives 77ss a cigar and a kewpie doll*
BTW its RED ....not pink :fist: faded out GM crappy paint. :x
PostPosted: Sat Mar 08, 2003 1:57 pm
i noticed it last night, just figured i'd leave it alone. you have a 4 door with a V6? rare find indeed!!
PostPosted: Sat Mar 08, 2003 3:43 pm
nope mine is a 4 popper...2.2
PostPosted: Sat Mar 08, 2003 5:16 pm
WOOOOOOOOO HOOOOOOOOO!
cough, cough, uhhh, this must be a cuban!
the car color looks a little red. its the ribbon stuff- too much pink. Make it stop- man.!
g
PostPosted: Sat Mar 08, 2003 8:10 pm
good motor anyways!!
 Post subject: fueul pump?
PostPosted: Mon Mar 10, 2003 10:07 pm
i have a 1981 4x4 4 speed isuzu 4 deisel : well my filter light is on so i put a new filter (fuel) but now it wont start like its not gettig any fuel could i have done anything wrong or was it the fuel pump all along?
 Post subject: diesel filter
PostPosted: Tue Mar 11, 2003 3:55 am
it sounds like you got air into trhe system. You will need to bleed the air out. Some diesels have a bleeder screw on the pump or a small lever that is used to evacuate the air. My best advise is to contact a diesel mechanic. I have a F350 that would cut off going down the road, The mechanic I got was worth his weight in gold! That truck never ran so good! I know very little about diesels, just enough to mess them up, I guess. Good luck
1980 4X4 LUV
PostPosted: Fri May 02, 2003 1:00 am
same here
