It is currently Sat Dec 13, 2025 2:17 pm
 Post subject: 80 luv axle swap
PostPosted: Tue Mar 07, 2006 10:30 am
how much do you guys think a front axle swap from an old yoda onto an 80 luv would cost? and what about steering? and geering? what shocks? where to place the leaf spring mounts? anything else will me helpfull
and how much performance would a performance cam increase power? and with a cam would you have to change anything else ??????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
PostPosted: Tue Mar 07, 2006 12:05 pm
you should buy my dana 30 front :lol: , all you'd need to do is biuld shackles and spring mounts, the steering box just bolts to the frame, it has all the steering linkage, it came out of a '79 or '80,
but, anyways, a yota front is gen. $250-$350 for the axle hub-hub, then you have to get a drag link made (gen.$85 for weld in bungs, TR ends, and tube), and figure out what springs to use (waggy's 5/7 leafs are real good) then a d-line, if you do a square shaft it'll be cheap, a custom made shaft will be $200 - $450 depending on whether or not you do a long travel. shocks will have to be determined once you get it in and cycle the suspension (max./min.) a lot of what you're asking REALLY depends on what you want the finished product to do. do you want a super flexy rock crawler or something to DD and minimum trail use??? maybe tell us what you plan on doing with it and we can give a little more specific info. :wink:
"I'll take 'The Rapist' for $1200 Alex..."
"That's 'Therapist' Mr. Connery"
PostPosted: Tue Mar 28, 2006 8:41 pm
i want a super flaexy dd weekend warrior
PostPosted: Tue Mar 28, 2006 9:17 pm
honestly i would just pickup Boonie Busters D30 front. Its not quite as stout as a toy 8" but it will be plenty strong for a luv. You wont be able to beat that price...
PostPosted: Tue Mar 28, 2006 9:24 pm
x2 :D not just because i'm trying to sell it, but it definitely would be an easy project. and actually i might have a different set of springs you could use with it. because unless you pull a bunch of the leafs out of the pack that's on it now, it'll be a very stiff ride.
PostPosted: Tue Mar 28, 2006 9:30 pm
oh also, as far as super flexy DD, i used a set of wagoneer rears up front with a few extra leafs to hold up to the v8 weight. but what i was gonna say was, use nitrogen charged shocks if you can find some cheap ones. i was lucky enough to get a set of 4 for $80, they're the longest skyjacker makes( not that you'll need them that long, because every setup is different and it doesn't always pay to have the longest shocks out there). they handle very well on the road, as far as turns are concerned. and when i go wheeling i still get all the flex that the waggy's have to offer.
PostPosted: Tue Mar 28, 2006 9:51 pm
Alot of the guys i run with run Gabriel shocks. They are gas charged and work realy well. I know of 5guys that swear by em. Im perty shure they get em from Auto Zone.
PostPosted: Tue Mar 28, 2006 10:13 pm
gabriels are 8)
PostPosted: Tue Mar 28, 2006 10:17 pm
thats what ill be running when i start my LUV build up...
PostPosted: Tue Mar 28, 2006 10:21 pm
Undefeated in Trivia
I'll be running Rancho RS5000s (probably 2 for each corner of the truck), mainly because they'll be free. A good leafspring to use is the Rancho 44044s (wagoneer 2" lift springs).
-Brandon
PostPosted: Tue Mar 28, 2006 11:20 pm
Banishment Pending
The waggy 44044's are good for the Luv setup, Isuzu guys swear by them for SAS. as far as shocks go another option would be Pro Comp ES9000's their a pretty good nitrogen shock(double tube I believe) that won't break the bank, they run about $36 a shock which isn't bad for a good all around shock. Axle wise, If you can get Booney's D30, it may not be the strongest, but it will more than hold up to the abuse of a 4 banger Luv, just don't run anything taller than a 35" tire with it, unless you like replacing axle shalfs and u-joints. If you're not going for Booney's D30 another axle you could go with would be a D44 from a Wagoneer, width wise it's perfect, and it has the pass. side diff, so that way you can use your stock t-case. and yes a performance cam will give you more power, why do you think they call it a "performance" cam??? :roll:
PostPosted: Thu Mar 30, 2006 4:46 pm
well after thinkin i think that i will keep it stock but i would lke to know
any precautions in installing a 2" or 3" body lift kit , cut up the fire wall for steering column, brake lines ect get back to me asap oh and look @ my pic in the off road owners gallery and see if you think a BDL would look good on it and by the way i dont want to change tires dere brand new!!!!!!!
PostPosted: Thu Mar 30, 2006 4:56 pm
Banishment Pending
you'll be fine with the brake lines, the only thing you need to do for the steering colum is to cut a 1 1/4" hole below the current one, there is a mounting plate included in the PA bodylift kit, and yes of course a 4x4 Luv will look good with a body lift, as far a tires go, yeah of course you can keep the surrent ones, it may look a little funny but so what, you can get bigger ones next time.
PostPosted: Thu Mar 30, 2006 5:02 pm
Thanks do i mount up the steering column on th estock holes?
PostPosted: Thu Mar 30, 2006 5:07 pm
Banishment Pending
On the inside of the cab, yes, the kit comes with some spacers(but i didn't use them, didn;'t really need them) in the engine compartment, yes/no, the mounting plate that comes with the kit bolts to the stok location, but the steeing colum bolts to the mounting plate(which has 3 studs built into it, you bolt the colum's flange to this)
PostPosted: Thu Mar 30, 2006 5:09 pm
Thanks were's your truck in the gallery and under what name so I can see your BD?
PostPosted: Thu Mar 30, 2006 5:14 pm
Banishment Pending
I don't have any pics up in the gallery, I haven't had time to post any, when i can I'll take some and post them.
