It is currently Sat May 02, 2026 2:48 pm
Post new topic Reply to topic  [ 166 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Wed Dec 14, 2005 12:13 am
800... just let me know what you need to know as i finally got every year service manual with the exception of the series 11 supplement for diesel. i can look up all the info you need and get it to you.. :wink:
PostPosted: Wed Dec 14, 2005 12:55 am
I was thinking of incorporating the info into the site like this page. http://www.luvtruck.com/history.htm I can do the integration but I need someone(s) to write the actual article. I think you both are good candidates. Would you to both work on it together?
Of course your names will be on it, unless you don't want them on it.
I think I'm going to pull the info out of some of those .pdf's in our info section and make them web pages as well as .pdf.
PostPosted: Wed Dec 14, 2005 1:15 am
Undefeated in Trivia
That would be a good idea because HTML pages load faster than PDF...
PostPosted: Wed Dec 14, 2005 8:59 am
i'm game on getting the info together. it sounds like 800 has a big chunk of it already. but i have manuals and some time to look stuff up for him, or i can get the info from this post and work something up...
either way is cool...
PostPosted: Wed Dec 14, 2005 1:53 pm
Some of this is my own curiosity, but I can use pretty much all of it in writing this stuff up. Here is what I'd like to know:
Rear axle ratios as listed in the service manual (fronts where applicable)
Speedo gear listings
Transmission gear ratios, unless they are pretty much all the same (which I think they are)
I think I have most everything else covered, or at least well enough to do a draft and then you can check my facts. Between the service books I have and that parts guide I can figure out most everything. I need to start collecting service manuals again, I was on a roll but my life got in the way of things.
PostPosted: Wed Dec 14, 2005 2:17 pm
800... i'll get that info for you. i'll get the info on capacities cause i know that the early models have smaller tanks. anyway i digress. i'll get that together before friday
PostPosted: Thu Dec 15, 2005 9:20 am
just as an update for Finalman.. the gas tank for the 82 longbed is a bigger one. i read it last night, but forget the actual. i can look it up if anyone needs it.
PostPosted: Thu Dec 15, 2005 9:22 am
it's 19.2 I think, it's in my dad's manual and I read it the other night too, I just didn't want to scan it and all that.
PostPosted: Fri Dec 16, 2005 6:42 pm
18.5 for the 81/82 longbed
10.0 for the 72/73 trucks
13.2 for all the rest
PostPosted: Fri Dec 30, 2005 2:17 am
im new i own a 77 mikado and i was just wondering were you huys get your restoration parts
PostPosted: Fri Dec 30, 2005 8:54 am
Welders, junkyards, and kind people that sell their luvs for cheap. But there are other places.
PostPosted: Thu Mar 09, 2006 9:53 pm
it has been a long time for info but i have a bite for you all some may know this. the 72-73 has a wider tail gate i tride to put one on along time ago it did not fit :cry:
PostPosted: Mon Mar 20, 2006 11:09 pm
The MOST unique... Mine the 1974 LUV eh.... Why dont I see many 74's in here. My favorite part of the LUV are the rear lights (below tailgate) and the four headlights. Most luvs have only two.
When I got it I noticed the manuel choke and ebrake. Then I seen the ISUZU 1.8L and Hitachi carb. I didnt know that the earlier years were considered Datsun Pups and Chevrolet was using foreign engines, which is good because apparently the chevy engines sucked big time. First thing I did is get rid 0of all emissions 8) and cut the restrictor off the exhaust.
Currently installing 32/36DGEV Weber with fun complications. TRIAL AND ERROR IS A SONOFABITCH
1974 stock engine
New: Accell Coil/Accell Plugs/Platinum Wires/Pertronix Pointless System/Fuel Pump/Weber 2Barrel Downdraft/ES3000 Explorer Pro Comp
 Post subject: 74
PostPosted: Wed Mar 29, 2006 11:29 am
did all 74 have taillights below box or did some go in bed sides?
PostPosted: Wed Mar 29, 2006 12:21 pm
Banishment Pending
74, the tail lights were below the tailgate i believe.
and 74Luver, the Luv was built by Isuzu, it was not built by Chevy using a Japanese motor. the only thing "Chevy" about it are the emblems, and badges. all of the mech. of it are pure 100% Isuzu. And no they were not considered Datsuns :roll:
on a side note, I wonder if the gas tank from a 81-82 longbed would fit on a 76-80 short bed, i sure wouldn't mind having a couple extra gallons of gas with me, would just about double the range too 8)
PostPosted: Wed Mar 29, 2006 5:45 pm
The 81-82 tank fits on the other side of the truck, the exhaust would be in the way. It might fit backwards on the other side though, but the length would be an issue, frame crossmember in the front and the axle on the rear side.
PostPosted: Wed Mar 29, 2006 5:52 pm
Banishment Pending
there went that idea, thanks for sheding light on it though 800
PostPosted: Wed Mar 29, 2006 10:03 pm
Would that tank fit in an older longbed?
PostPosted: Thu Mar 30, 2006 1:07 am
I've never tried either swap, so I can't say for sure. I'd guess you'd have less trouble on a longbed to longbed swap, just because the length problem would not be as bad.
My idea was to swap an 86ish Trooper rear mount tank in place of the spare tire. It holds more than 20 gals, should close to triple the range if the stock tank was left in place.
PostPosted: Thu Mar 30, 2006 1:12 am
Banishment Pending
now there is an idea, I already got ride of my underbed spare tire carrier (or should i say it was taken off before i got the truck) and ther is a ton of room under there, shoot an extra 20gal or gas, that means I would have a range of about 650mi, thats with a total capacity of 33 gals x an average mpg of 20 = 660mi, sweet i could get into that, only having to fill up once a month or so :twisted:
