It is currently Fri Jun 19, 2026 6:48 am
 Post subject: one for flyboys
PostPosted: Mon Mar 27, 2006 4:29 pm
found on another forum
This Is a funny one for anyone who works on any kind of aircraft, or any machines that require a log to be kept on maintenance and service inquires. I fix aircraft for a living, you will find this one funny even if you do not.
It takes a college degree to fly a plane but only a high school diploma to fix one: a reassurance for those of us who fly routinely in their jobs.
After every flight, Qantas pilots fill out a form, called a "gripe sheet,"which tells mechanics about problems with the aircraft. The mechanics correct the problems; document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by Qantas' Pilots (marked with a P) and the Solutions Recorded (marked with an S) By Maintenance Engineers.
By the way, Qantas is the only major airline that has never had an accident.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.& nbsp;
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny. (I love this one!)
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
And The Best One For Last !!
P: Noise coming from under instrument panel . Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget
PostPosted: Mon Mar 27, 2006 5:33 pm
:lol:
PostPosted: Mon Mar 27, 2006 7:16 pm
i like that, thanks for the :lol:
PostPosted: Mon Mar 27, 2006 9:14 pm
that stuff rocks :lol:
PostPosted: Mon Mar 27, 2006 9:29 pm
That was funny!! Good way to start my night! Thanks larp!!!!!
PostPosted: Wed Mar 29, 2006 10:49 am
LOL!!! I'll send that to my dad. He's an aircraft nut.
