It is currently Sun Feb 01, 2026 10:10 am
PostPosted: Wed Mar 22, 2006 10:00 pm
Without getting into a turd-flinging debate, Who's running what on their V-8 street engine. I'm running full manifold vacuum advance to my distributor.
I'm curious to see how things stack up.
PostPosted: Wed Mar 22, 2006 11:43 pm
Swap Specialist Mod
ive always ran the dist off the ported port on the carb.
PostPosted: Thu Mar 23, 2006 3:51 am
it should probly be run off ported vacuum. With full manifold your always pulling advance. I have done this with engines before it just means you usually set initial timing a bit lower is all.
PostPosted: Thu Mar 23, 2006 6:09 pm
ported. My manifold goes to the trans and the booster
Resident lurker
PostPosted: Sat Mar 25, 2006 12:36 am
Japanese Redneck
I run mechanical but if i run vac adv then I run ported vacuum or lock it out completely and use the MSD dial to retard for startup.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Sat Mar 25, 2006 12:42 am
It must be ported. As you go to WFO you actually have no or less vacuum in the manifold. So if you timed it with manifold vac, you will release the vac advance and retard your timming, the only advance you would have is mechanical.
PostPosted: Sat Mar 25, 2006 9:40 pm
Here's a link to a .pdf file that covers this subject in detail. It helped me zero in on my particular configuration. Now im not saying that any of you are wrong about your advance setups, but the info is worth reading to fine tune your motor to your application.
http://home.comcast.net/~chadwick.rober ... lained.pdf
