It is currently Mon Jun 08, 2026 10:41 am
 Post subject: Fuse Block
PostPosted: Fri Mar 24, 2006 11:17 am
Anyone know which part place to get a fuse block? My fuel pump keeps cutting out and now I neeeeeed one.
M
PostPosted: Sat Mar 25, 2006 12:08 am
Its either a junkyard part, or maybe ebay for a NOS one but don't hold your breath. You could use a generic one though, find a blade style fuse block with enough circuits and use it instead.
I took a spare old one I had and shined up all the contacts with sandpaper and a dremel tool. Then I swapped it wire by wire with the one in my truck. I also put some electric contact grease on every wire connection on the bottom and each fuse holder. Seems to have done the trick for the headlight problems I was having.
PostPosted: Sat Mar 25, 2006 6:18 am
i thing your best bet will be a junk yard. But as ill be up with my parts trucks here in Paril ill check out my 78 for ya. It should still have one.
PostPosted: Sat Mar 25, 2006 2:09 pm
I've got one I can send to you.
Does any body know if the fuse block is the same for all years (72- 80)?
Because I don't know what year this one came out of.
PostPosted: Sat Mar 25, 2006 5:39 pm
they are different
72.............p/n 94021153
73-74........p/n 94022842
75-77........p/n 94023973
78-79........p/n 94027160
80.............p/n 94029308
those p/n's are for the box assy.
PostPosted: Sat Mar 25, 2006 7:02 pm
Thanks Bob. I'll see what I have in a couple days. Work finally picked up a little. I am working all night Sat and Sun. morn. and Monday.
I know I have 2 fuse blocks, I don't know what year they are for.
PostPosted: Wed Mar 29, 2006 2:58 pm
I can't find a part number on it. It matches up to the one on my 80.
PostPosted: Fri Mar 31, 2006 3:00 pm
That is the same one that I just ripped out.
I went down around the corner to the autoparts place and was shooting the shit with the manager and he come walking around the corner with two generic fuse blocks. I put them in and now she runs great.
Now the problem is that I am at work and there's no spark at the plugs. She just died on me.
So here I go again. By buddy is bringing me a condenser, so hopefully that is the fix. I de-carboned everything and generally when that does that, it is that stupid condensor.
