It is currently Sun Jun 07, 2026 2:03 pm
 Post subject: drive shaft
PostPosted: Wed Mar 05, 2003 4:57 pm
how do i take the end of my drive shaft off i took the little pins out but i can't get it off please help.
PostPosted: Wed Mar 05, 2003 8:04 pm
if i remember, the driveshaft is bolted together- two flat surfaces with bolts thru them. after the bolts sre removed, there are still two little studs connecting one plate to the other. maybe a good whack?!?
Id wait for a second opinion though. strange thing, my ford 9 has the same set up, only beefier. :twisted: mmmmm beeeeef.
after rereading your post, im not sure if i tried to answer what you were asking. :?
If your trying to remove the u joints, remove the c clips and support one side- take a socket and whack the other side. should inch it along out da hole.
Users browsing this forum: Bing [Bot] and 19 guests
