It is currently Mon Jun 08, 2026 1:12 pm
 Post subject: Anyone got info
PostPosted: Mon Mar 13, 2006 9:45 am
Anyone know what kida fuel pump would be a good replacement for a 76?
She goes down the road and dies, in checking the filter (I love clear filters) there is merely a trickle of fuel going in there.
Let me know some part nos if you gots them!
PostPosted: Mon Mar 13, 2006 8:21 pm
The actual replacement pump when I checked at Napa was over a 100 bucks. I just went with the $30 universal instead...
Resident lurker
PostPosted: Mon Mar 13, 2006 8:23 pm
yea i did that to
my frends dodge says its eaten chevys and shiting fords well i say AT LEAST ITS EATING SOMETHIMG GOOD
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Mon Mar 13, 2006 9:39 pm
The one that I was looking at said that it was keyed off the oil pump. I thought that was doo-doo.
But in any case. Is it OK to get the electronic rather than the electric?
PostPosted: Tue Mar 14, 2006 11:48 pm
I got he same 30 pump to
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Wed Mar 15, 2006 9:16 am
Well, I found what the problem was. It wasn't the pump after all. It was the fuse block.
I was running down the road, and the GEN light came on. So I opened the hood and saw that the Alternator was happy, so I reached under the jumper block out of a hunch and there was a crapload of loose wires. I got her home and started replacing the ends, and Bingo, all problems went away.
