It is currently Mon Jun 08, 2026 11:53 am
 Post subject: Luv dies out (fixed)
PostPosted: Sat Mar 04, 2006 5:23 pm
I tyred to put a second fuel filter in and I drove it around and ever time I put the clucth in when it was in a gear and I was just rolling up hill and down hill it would do it. so i thought it was thes second fuel filter I just put in so I took it out and ran it normal so I started it up had it running at idle gave it gas and it died tryed to start it had to keep my foot on it to run and it was doing the same thing again but I drove it a bit it stop doing it. And a little bit later I put the clucth in step on the brake and it died. could this be fuel pump.I need help guys
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Sat Mar 04, 2006 7:30 pm
Banishment Pending
check the fuel filter, check the fuel pump, and check the ide, and also check the timing, and the points as well, there a number of things that could be making it die. You just got the check all of the above stuff.
PostPosted: Sat Mar 04, 2006 9:34 pm
fuel pump is working I can see gas going thro the filter I think its a vacum hose on the carb
79 4x4 1.8 liter
PostPosted: Sun Mar 05, 2006 10:40 am
That is very possible. You have been poking around in there with your temp gauge deal, so you might have knocked one off or cracked a old rotten one.
PostPosted: Thu Mar 09, 2006 9:58 pm
turns out it was the fuel pump replaced it no more problems
79 4x4 1.8 liter
PostPosted: Mon Mar 13, 2006 11:11 am
What was the pump you put in? You got the part number?
PostPosted: Mon Mar 13, 2006 6:16 pm
it was just an electric pump not a stock one
79 4x4 1.8 liter
