It is currently Thu Jun 11, 2026 5:26 am
 Post subject: rotary motors
PostPosted: Wed Mar 01, 2006 3:09 pm
are rotary motors say like a twin turbo 13m able to be put in these trucks? cause i have a guy here locally that has an rx7 shop. also it would be good cause its 5 speed and you can have more upgrades plus turbo.
PostPosted: Wed Mar 01, 2006 4:36 pm
Banishment Pending
well the Aussies are putting them into Gemini's so I would assume that you could fit on into a Luv.
PostPosted: Wed Mar 01, 2006 7:27 pm
I have thought of that myself I think it would be easy to do . if my new motor ever takes a dump i just might do it, go for it man and lets us know how it turns out
PostPosted: Thu Mar 02, 2006 12:27 am
I don't see any reason why it wouldn't fit. Rotaries are a small package compared to piston engines.
PostPosted: Thu Mar 02, 2006 2:59 am
Only issue I can think of is gearing. Rotaries put out some serious RPMs and often have differential gears to match.
I knew someone years ago who dropped a SBC into an old Mazda rotary pickup. The rear end was geared so high it was a challenge to get 55MPH out of it. The driveline ended up giving out after a week or so and took care of removing the rear end for him though.
PostPosted: Thu Mar 02, 2006 8:03 am
Yeah gearing is the only realy big thing. The Mazda REPU pickups (yup you guessed it a B series whith a rotory 8O ) had 4.77 gears in the rear end. The bigest problem whith the rotories is they have NO low end power, and if you lug em the engne is done...
Users browsing this forum: Baidu [Spider] and 6 guests
