It is currently Wed Mar 25, 2026 11:40 am
PostPosted: Tue Feb 28, 2006 9:15 pm
i am really tired of trying to get the stock motor to run agane and i do have a blood lust for HP so i am really excited about puttin a bigger motor in .My frend matt (screen name)>brat with a brat has helped me a lot on this truck but we still cant get her to purr agane. So it 350 time and i would like some info on this swap befor i invest to much money in it
thanks a million Xnick
my frends dodge says its eaten chevys and shiting fords well i say AT LEAST ITS EATING SOMETHIMG GOOD
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Tue Feb 28, 2006 9:39 pm
Well there is a ton of info here for ya, so start with the search button 1st!!!!!!! Then if you still have questions we are here for ya. If you have the right tools, it is not that big of a job! Good luck, and welcome aboard!!!!!!
PostPosted: Tue Feb 28, 2006 10:16 pm
empty engine bay, bolt motor and tranny together, set in hole and fab some mounts. It's almost that easy. I'm using block huggers. move e brake wheel as in hooker instuctions. Grind a little on heater hose mount. Buy the aluminum radiator and make it fit. Have a drive shaft made. Finish any loose ends, hoses, belts, wiring, exghust. I'm about 3/4 of the way through with the install on my 78'. The people here are a great help.
PostPosted: Tue Feb 28, 2006 10:35 pm
First place you should start is http://www.luvtruck.com/Information.htm
There is a how to for fitting a small block into a luv that should give you a good idea of what you will be needing to know.
