It is currently Sun Dec 07, 2025 11:25 pm
PostPosted: Thu Feb 16, 2006 1:26 pm
my buddy has a rodeo that he's taking the 4x4 runnig gear out of and i get it all. i know the rear end will work. its got 4.10's disk brakes, electric locker!. from the front i get the whole spindle and rotor asembly c.v. joints and axle basicaly everything but the a-arms. but i was thinking that all of that would be a nice update and up grade for my 79. we are going to see what we can get to fit this weekend.
1-2 it's not new, 3-4 shave the door, 5-6 learn some trix, 7-8 make it scrape!, 9-10 show your friend!
PostPosted: Thu Feb 16, 2006 1:30 pm
Banishment Pending
the front end you got there is an Isuzu 10 bolt, pretty beefy IfS unit, you can try to swap the axle and cv's over but I don't know if they'll fit. The rear end unit you got there isn't the bullit proof 12 bolt though, Rodeo's got the Dana 44 rear end, not a bad axle, and there is a ton of after market stuff out there for it. Good luck and let us know what you find out with the IFS swap
PostPosted: Fri Feb 17, 2006 4:58 pm
my understanding is that in opder to upgrade to the 10bolt front pumpkin you need to replace everything from hub to hub. You might even need to modify the A-arms as i think the steering knuckles are different.
PostPosted: Fri Feb 17, 2006 10:14 pm
I'm not even sure if the width is similar between a Rodeo and a LUV. I bet you'd have to swap a lot more than just diff, tube, axles, CVs, and hubs though.
I've seen a couple of people who have swapped out the 8 bolt in an 87 Trooper for a 10 bolt, but that is a special year, came with both depending on when it was made. Could be with the combo of parts it might all bolt right up, but it might take a bit of detective work.
PostPosted: Sat Feb 18, 2006 9:45 pm
well i pulled the front axle's yesterday. kind of pain in the a$$, but i need to locate some pup spindles to swap in the front for the 5 lug for the rodeo then i get the spindles and disk brakes(they're huge the smallest wheel that fits around them is a 16") i hope i can get it all to fit!! the only thing that sux is it has the auto locking hubs so i need to get some manual hubs.
