It is currently Fri Jun 12, 2026 6:09 am
 Post subject: changin things up a bit!
PostPosted: Mon Feb 13, 2006 11:39 pm
well my 75 2wd has a bent frame i found out after my swap was all done! :evil: all the work wasted....any ways im thinking of pulling my tbi 4.3 and swaping it in to my 79 4x4 then running a chevy 10 bolt posi rear end then a dana 30 front axle with a divorced np205 what do you guys think? oh and it will be on 33's
1-2 it's not new, 3-4 shave the door, 5-6 learn some trix, 7-8 make it scrape!, 9-10 show your friend!
PostPosted: Tue Feb 14, 2006 12:19 am
Swap Specialist Mod
get another frame for the 2wd. s10 blazers are everywhere and damn near a dime a dozen. im sure you could find a frame for pretty cheap. the bagged luv kicks ass man. you gotta keep it goin!
PostPosted: Tue Feb 14, 2006 1:30 am
Twist of fait, I was down your way today, is your 4x4 the one sitting on Walnut not far from US Bank?
PostPosted: Thu Feb 16, 2006 1:05 pm
nope thats one is grey mine is rattle can blue! im like 3 blocks down from that one. haha :D
anyways im going to be pulling my 2wd apart and keeping the body in a storage. i got another 4.3 thats carb that im going to build for it an im going to be rebuilding the truck back on a luv frame cause i found all the weak spots of the blazer frame(the s10 pick up frame is differnt) and to be rid of most of them i would have to cut the frame off be hinde the a-arms and start from scratch. I dont have the time, the shop, or the money to do it right now but hopefull this summer i can get back to work on it!
PostPosted: Thu Feb 16, 2006 5:55 pm
Would it be easier to have a body shop pull the frame straight? I would seam to me it would be allot less work.
PostPosted: Thu Feb 16, 2006 10:46 pm
3 blocks eh, I'll have to look harder next time I'm down there. :) Looks like I'll be doing some work down there sometime in the next month or two.
PostPosted: Thu Feb 16, 2006 10:54 pm
cool maybe we can meet or something and shoot the shit, as for the 2wd it's not just the frame being bent the frame was cheaply made so even after boxing some of it and adding 3 crossmebers the frame still flex's side to side. the blazer frame was a bad base to start with. an s10 pick up would be a lot better!!!
 Post subject: 4x4
PostPosted: Mon Feb 20, 2006 5:56 pm
dude you got to put that motor in the 4x4. nodoubt. it would be sick.
Rev Limiter! what Rev Limiter!
