It is currently Mon May 25, 2026 6:45 am
PostPosted: Fri Feb 28, 2003 9:45 am
Dont know if second generation is correct, but when they changed body styles in 80 or 81, did they change the front suspension to a control arm/coil spring or did they keep the torsion bar set up?
PostPosted: Fri Feb 28, 2003 1:00 pm
I had a 2WD 83 Isuzu Pup for a while, which should be like the 81+ LUV. It had a slightly different torsion bar setup, but still torsions. It basically looked to me more like the setup that is on the 4x4 LUVs than the 2WD older ones. Not exactly like the 4x4, but closer to it than previous 2WDs.
The calipers were different, rotors looked different, as well as a lot of the various bars and bits.
PostPosted: Sat Mar 01, 2003 12:27 am
i agree with 800xl i have an 81 and have looked at older ones, basically the same....
later
E
PostPosted: Thu Mar 27, 2003 2:57 am
If there both a bitch to take apart then yes they are the same. My 81 isn't different than any other I've seen.
Dave
Users browsing this forum: Google [Bot] and 24 guests
