It is currently Mon Dec 15, 2025 3:33 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
 Post subject: mini starters
PostPosted: Tue Jan 03, 2006 3:06 am
Anybody runnin v8's, Have, or have used the mini starter? Any comments on these are appreciated. :wink:
PostPosted: Tue Jan 03, 2006 3:48 am
Swap Specialist Mod
cody and lee both have ministarters. they work great and make more room for the exhaust.
PostPosted: Tue Jan 03, 2006 6:21 pm
Japanese Redneck
I used a CSV or CSR or whatever name they go by now. it works great.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Jan 03, 2006 7:48 pm
I have a Hitachi on mine. It works great.
VALLEY VIEW AUTO SERVICE
up, and running:)
PostPosted: Tue Jan 03, 2006 7:56 pm
I got the hitachi on mine also, I bought it from summit.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Jan 03, 2006 9:23 pm
So, what are you generally paying for one? I am watchin a couple on ebay, and they seem to be about $50.
PostPosted: Tue Jan 03, 2006 11:26 pm
Japanese Redneck
I paid $150 but the price may have come down some. 50 sounds really cheap though. Make sure its a 4.44:1 ratio and not the 3.whatever. Hitachi's are good (actually i think they make a large portion of the mini starters sold under other names). JEGs and SUMMIT have their own mini starters too. I've just had the best luck with the CSV
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Jan 03, 2006 11:31 pm
cool, thanks for all the info!! My starters about to take a crap, and I will be buying a new one soon, and I think I wanna go "mini".
PostPosted: Tue Jan 24, 2006 6:41 pm
Try to shy away from the ultra cheapie junk china made starters.. I had one and it snapped the drive gear off in the first week. I have been running a Hitachi with no problems.
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
PostPosted: Wed Jan 25, 2006 1:02 am
Swap Specialist Mod
its kinda funny how hitachi makes great starters ,but crappy carburetors :roll:
PostPosted: Wed Jan 25, 2006 4:43 am
Okay, heres another question. 1- How many of you guys, that have rplaced a chevy starter ever uses the shims? I have replaced tons in my day, and have never used the shims. So heres why I ask, I just swapped the starter in my truck, and it kinda sounds a little screechy. So I am wondering if shims are in need! A new starter always comes with 1 or 2, but like I said, "I have never used them". Thanks T. --- P.S it took me about 5 hrs to swap my starter cuz I had to drop my passenger side exhaust, to get the old one out and new one in :evil: What a bitch of a time I had! :evil:
PostPosted: Wed Jan 25, 2006 4:47 am
Swap Specialist Mod
were using 2 shims on codys truck. when the shims arent used it bogs the starter. the screechy sound sounds like you need some shims.
PostPosted: Wed Jan 25, 2006 4:52 am
Thanks Joe, I guess I will get back under it sooner then I thought :!:
PostPosted: Wed Jan 25, 2006 4:57 am
Swap Specialist Mod
no problemo!!!
PostPosted: Wed Jan 25, 2006 11:06 am
Well the proper way to "adjust" the starter on a chevy, is to shim it till you can fit a paperclip between the teeth, or I think it's about .060". If you have more than that you can get by, but less and it will drag and burn the motor eventualy.
Shims always move the gears apart, there was a good article on the net about how much to shim with x amount of tooth clearance, you might do a search.
63 Nova
74 Camaro
PostPosted: Fri Jan 27, 2006 11:26 am
Japanese Redneck
ah u beat me to the paperclip gauge method. I believe the starters actually come with instructs to do that. in any case most new starters don't require shims but if you ever get a remanufactured one where it was surfaced then you may need shims in place of the material that was machined off in order to get the starter closer to the flexplace/flywheel again.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Fri Jan 27, 2006 12:38 pm
Great rednecks think alike LOL
63 Nova
74 Camaro
PostPosted: Fri Jan 27, 2006 10:36 pm
Thanks alot guys!!!!!!!
PostPosted: Sat Jan 28, 2006 9:36 am
I was thinking the same thing. I think a guy at work told luvnit the same thing. :D
Resident lurker
PostPosted: Tue Oct 24, 2006 8:00 am
I bought the mini starter too to avoid the hot starts and it ate my stock flywheel (I think it was about gone anyway as the original stock starter was catching at times). I bought the TCI flywheel and now I'm needing to shim the starter too. Like Luvnit, I've never had to shim before. My brother told me to shim ONLY the outside, a friend told me to shim only the inside, I'm leaning on shimming straight across and not just one side or the other. Last night my son shimed only the outside and allowed for the wire clearance (.020 I think) as noted on the instructions and checked it in three different places like the instructions said. Any thoughts on which way is best. Of course I had to pull the motor to swap the flywheel so I want to get everything adjusted before I put the motor back in so hopefully I don't have to crawl under the truck anymore than I have to.
1980 shortbed Luv - 350 40 over, etc. - Like I told my momma, it ain't no fun growing up!
