It is currently Sun May 10, 2026 5:20 am
 Post subject: headers
PostPosted: Sat Jan 21, 2006 6:34 pm
I was doing some clean up today on my truck I just pulled the motor and trans out and found that my Right side exhaust manifold is cracked. Im thinking about switching to headers now. What headers will work in a LUV with a sbc and clear everything?
PostPosted: Sat Jan 21, 2006 8:46 pm
Please do a search, this topic comes up all the time. Two choices, block huggers or hooker headers that are made for the LUV.
PostPosted: Sat Jan 21, 2006 10:44 pm
Japanese Redneck
actually3 choices... Hedman Husler fenderwell's for S-10 but this option is really critical on how ur motor is positioned and is also the most expensive option. Its also geared towards a high perf - full race application as the primary header tubes are 1 7/8" or 2"
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Sat Jan 21, 2006 11:45 pm
I was hoping the block huggers would fit. I found a pair through summit I am probably going to order monday. Im not really a big fan of headers for street use but I guess its a cheap alternative for now if I cant find another ram horn in good shape.
PostPosted: Mon Jan 23, 2006 2:09 pm
I just put Headman block huggers on mine without a hitch.
1980 shortbed Luv - 350 40 over, etc. - Like I told my momma, it ain't no fun growing up!
PostPosted: Mon Jan 23, 2006 8:22 pm
why is this in dirvetrain in the first place???
PostPosted: Mon Jan 23, 2006 9:45 pm
seems like the right place for a sbc exhaust question
PostPosted: Mon Jan 23, 2006 10:02 pm
I guess I could of posted it in the stock truck section and labeled it something like HELP IM STUPID
PostPosted: Tue Jan 24, 2006 12:19 am
Swap Specialist Mod
you notice the section is called "Drivetrain Upgrades. Discussion about engine swaps and related drivetrain component upgrades such as transmissions and rear axles.
PostPosted: Tue Jan 24, 2006 2:42 am
I think I have a set of ram horns, I am not ever gonna use. If so, and you still need em, maybe I will bring em to the meet!
PostPosted: Tue Jan 24, 2006 11:06 am
Japanese Redneck
just keep in mind, there are 2 kinds of ram horns. the ones with the 2" outlet are the ones you want to use on a performance application.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
Users browsing this forum: Bing [Bot] and 14 guests
