It is currently Tue May 26, 2026 5:59 am
 Post subject: front coilovers
PostPosted: Fri Jan 20, 2006 1:20 am
Hey guys i am wondeing how many people have put coilovers in the front shock spot f there luvs i saw one pic in the projects section by jeff i believe and i was wondering what i need to do in order to do this. i am not really sure on how to measure for the length of the spring and what not so some help would be cool oh yea pics of anyone else who has done this would be great thanks
PostPosted: Fri Jan 20, 2006 2:14 pm
QA1 shock #3855 is what I have. 11 1/8" extended, 8 5/8 compressed. QA1 spring # 7-350, 7" length. You can get them at Summit, Jegs or any other speed shop. Bottom mounts to the existing hole but the top youll either have to have some mounts made or buy some from a circle track store or street rod store. http://www.speedwaymotors.com has some nice ones.
PostPosted: Fri Jan 20, 2006 2:17 pm
Have you done a search here yet? Theres been a few other guys post pics in the forums before.
PostPosted: Mon Jan 23, 2006 4:20 am
Swap Specialist Mod
these are from andy bryant's gallery.
PostPosted: Mon Jan 23, 2006 4:26 am
Swap Specialist Mod
heres another one
PostPosted: Mon Jan 23, 2006 4:30 am
Swap Specialist Mod
and some more.
PostPosted: Mon Jan 23, 2006 12:40 pm
i see a blowoff valve on the last truck! is that supercharged or turbo?
PostPosted: Mon Jan 23, 2006 9:10 pm
man thanks guys so uch this helps a lot i am going to order this stuff tonight and get it in when i finish welding up my rear frame rails thanks
PostPosted: Mon Jan 23, 2006 11:50 pm
Swap Specialist Mod
its supercharged. check out tad kimblers truck in the gallery
PostPosted: Tue Mar 21, 2006 5:56 am
Is the ride height the same as a stock LUV or lower/higher than normal with the coil overs that you installed?
Let me xray you, you will feel better.
PostPosted: Tue Mar 21, 2006 6:43 pm
ON the shocks, the # 7-350, is the 350 the spring rate?
I am looking at the QA1 site and I found this:
QA1 7" X 2.5" I.D.
250=under 1200 lbs.
350=1200-1500 lbs.
450=1600-2000 lbs.
OK, I found it, 350 is the spring rate...pays to keep researching!
If this is correct, then what is the understood front weight with the small block?
I found this thread, basically rounding it out to about 2700-2800/give or take. ( http://forums.luvtruck.com/viewtopic.ph ... ght=weight)
So should we divide that in 1/2 or go 60-40% on deciding this #?
Also, on the top shock T-mount , what is the spacing off of the frame that most of you have?
PostPosted: Tue Mar 21, 2006 7:16 pm
I just took someone elses suggestion on the spring rate.
PostPosted: Sat Mar 25, 2006 12:50 am
Japanese Redneck
damn i wonder what spring that is on the blue SC'd truck its a progressive spring. I'd be interested in that.
Big Hap you do run the 350# rate right? I got the 350's but havent installed them yet. that seems like the logical choice. I'm looking for good weight transfer but I dont want the front end extending too fast . its really a challenge putting this HP to a true 10" tire.
On andy's truck I'd be interested to see how his steering shaft passes by the back header tube. Mine didnt clear so I had to "adjust" it and then back to shop to re coat it. my mistake mocking the headers up while the steering shaft was removed. D'oh!
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Mon Mar 27, 2006 9:17 am
luvsadrag...
what spring are you currently running and what can you tell me about the ride etc from it ?
72 L.U.V.
427 SBC-700R4
Mustang II front suspension
LUV perf parts manufacturing
My Devotion to Karl :
PostPosted: Mon Mar 27, 2006 11:20 pm
Japanese Redneck
i bought the Qa1 shocks with the 350lb spring but have yet to put them in cuz Ive got my stock torsion working so well i kinda dont want to mess with it. I will probably put them on later this year.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Wed Apr 19, 2006 8:32 am
I have been wanting to remove my torsion bars and go with front coil overs also for exhaust clearance. I can't find info on how to mount them.
PostPosted: Wed Apr 19, 2006 7:24 pm
Mounting them is sorta trial and error, but I am sure most should be based upon whatever manufacturer's stated travel #s are.
I am going to sort of modify what some have done here, but what is posted is a good start!
One guy I talked to suggested allowing for later adjustment, maybe factoring in different ride heights or whatever...
Im NO expert on these but I will soon discover what will work in my truck
72 L.U.V.
427 SBC-700R4
PostPosted: Thu Apr 20, 2006 9:27 am
I would say you would want to beef up both the upper and lower shock mounting points if you want them to carry the whole weight of the truck.
Bob.
PostPosted: Thu Apr 20, 2006 10:18 am
Id do that if I had enough confidence in my abilities but not know. I would like to know how to raise the front end with the torsion bar adjustment
PostPosted: Fri Apr 21, 2006 4:17 am
Under ya bum, well back near the rear of the gearbox are the adjusters. Theres a small bolt that holds a lock tab, undo that bolt and take the lock tab off. Wind the big bolt, not sure if its in or out, i cant remember its been a while. I think in lifts and out lowers.
My adivce it to had the truck on a hard level surface and keep a tape measure handy.
Cheers. Bob.
