It is currently Fri Mar 27, 2026 2:44 pm
 Post subject: Slicks?
PostPosted: Wed Feb 19, 2003 9:54 am
For all the luvs that are drag racing i was just wondering what size and type of slick everyone is running????????
PostPosted: Wed Feb 19, 2003 9:27 pm
Hoosier 31x16.5x15.
PostPosted: Thu Feb 20, 2003 12:41 am
what about without tubbing it??????????
PostPosted: Thu Feb 20, 2003 12:52 am
ET Drag 26x10's on 15" rims
PostPosted: Thu Feb 20, 2003 1:07 pm
I tubbed mine. took a couple weekends. I plan on detailed pics as soon as I roll it out in a week or two.
I got two rear frame pieces from a donor luv and welded them in place closer together, added some support pieces made out of stock steel, then cut out the old ones. by leaving the old ones in till the end, everything was square. then you just have to buy some of the sheet metal wheel tubs and cut them in.
g
 Post subject: slicks
PostPosted: Thu Feb 20, 2003 3:09 pm
M/T ET's 28x9 on a 14" rim
PostPosted: Mon Feb 24, 2003 10:12 pm
im not running slicks but i will be running a set of hoosier quick time dot tires. 255 60 15 i will have it on the track this weekend and let you know how they work.if i wouldnt have gotten such a good deal on these i would of went with the slicks. :twisted:
PostPosted: Mon Feb 24, 2003 10:18 pm
if you get the back spacing on the tire right you can stuff a 10-11" thick tire back there.
PostPosted: Mon Feb 24, 2003 11:25 pm
Fixed your post racelife.
PostPosted: Tue Feb 25, 2003 9:38 pm
cool thanks ben.its still not loging me on automatically it usually does this to me about once a month.i can usually log on and hit the auto button and it would work fine but this time its not. no big deal i`ll just remember to sign on each time later :twisted:
PostPosted: Tue Feb 25, 2003 11:47 pm
m/t 28x12.50 x15 street e/t as for the tubs i used two other fenders from a doner luv [junk yard] cut them out with a chisel and a hammer then trimed them and the bed and welded them in looks good and are cheep
PostPosted: Mon Mar 03, 2003 12:25 pm
4link - Did you move your frame rails in? or Did you just add the tub?
