It is currently Wed Jul 01, 2026 12:04 am
PostPosted: Sat Jan 07, 2006 8:26 pm
I have a 78 stepside with a 350 police and a 700r4 trans. The trans is making a clicking sound when it is in drive. i had it run for codes and none came back. the shop said they dont know the cause of the problem. it does not slip and hooks correctly on takeoff. any ideas? :?
PostPosted: Sat Jan 07, 2006 8:43 pm
yeah leave it alone before you break it. dont fix anything thats not broke.
PostPosted: Sat Jan 07, 2006 9:46 pm
Swap Specialist Mod
i bet its the governor in the tranny that clickin. is it a loud click or just a small tick? if its a small noise i wouldnt worry that much about.
PostPosted: Sat Jan 07, 2006 11:34 pm
Japanese Redneck
is it a constant click or just on decel?
is it more like a rattle?
does it do it when your're stopped or rolling?
does it do it when you're neutral too or just in drive?
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Sun Jan 08, 2006 5:49 pm
it clicks when in gear, does not when in nuetral. doesnt matter if it is stopped or rolling it does it, it is loud enough to be annoying but if i insulated the floor i wouldnt be able to hear it..
PostPosted: Sun Jan 08, 2006 9:36 pm
LUVTruck.com's Cornholio
I dont think a 700R4 has a governor. I think they have the Tv cable and thats it.. I think
PostPosted: Sun Jan 08, 2006 9:38 pm
You know it could not be your tranny at all. It could be a driveline sound or even the rear end and the drive line carrys the sound to the tranny thats why you may think it could be the tranny.
PostPosted: Sun Jan 08, 2006 9:41 pm
i think its the tranny cause it does it when now moving as well as when moving.
PostPosted: Sun Jan 08, 2006 9:43 pm
just so you all know, im in florida right now and the truck is in oregon so i cant go and check it.
PostPosted: Mon Jan 09, 2006 8:23 am
Yeah that might be just a little problem. :lol:
PostPosted: Wed Jan 25, 2006 1:22 pm
Cracked flywheel or loose bolts hitting flywheel cover?
PostPosted: Sat Mar 04, 2006 11:08 am
I like the idea of an overdrive gear in a V8 Luv.
So, with a basically stock sbc, would a shift kit-ed 700R4 hold up in a daily driver?
PostPosted: Sat Mar 04, 2006 12:04 pm
Yes.
PostPosted: Fri Mar 10, 2006 12:29 am
Will a 700R4 fit in luv with out hacking the trans tunnel?
PostPosted: Fri Mar 10, 2006 1:09 am
Japanese Redneck
mine required some minor "massaging" for the TH350 trans anyway but the 700 shouldnt be much different. I adjusted mine right on the line where the trans tunnel meets the firewall and both trannys are basically the same in that area. so i guess the answer is YES if you use the Hooker installation kit's directions to the T.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Fri Mar 10, 2006 3:20 am
i had that problum on my truck years ago one of the bolts got a little not tight so when you get back to your luv let us know what you find out
dangerous-toys4life
75 k-5 2x
94 king cab
