It is currently Wed Mar 25, 2026 3:44 pm
PostPosted: Fri Jan 06, 2006 1:10 pm
well. here's what I have going on. I just got a 76 luv that was converted when new to a 4x4 with dana 30 front 4:10 and stock rear axle, a unmaried dana 20 transfercase , turbo 350 trans and buick 350 engine. I got this over christmas vacation from a friend in oregon and towed it back to iadho. I got it runniong and the wiring figured out. But he was planning on putting a radiator out of a big chevy top kick or kodiack in the bed of the truck. I wanted to tuck one under the hood! I have 3 choices it looks like . I just got a like new radiator from a friend from a 75 nova it's a 2 core with trans cooler the height is 19" length is 26". The problem I see is the height becouse of the core support cross member. I have 16" from the cross member to the top of the core support. As far as mooring this support all I have is a old stick welder and Ill proably burn hole with that! I can weld great with a wire feed but I don't have one. The last choise would be a howe 342b but then I have the height issue again?? another concern witch I can post a pic is the the water pump snout sticks into the old radiator opening about a 1/2 inch or so!! any advice or pics would be welcomed here!! thanks -Brian
PostPosted: Sat Jan 07, 2006 10:33 pm
I think I will save up my pennies and get a how 342aa it's 16" x 27 1/2" tank to tank, 24 1/2" core width, I don't see how you can install a howe 342a 19" x 26" tank to tank, 23" core wouldn't that stick past the hood 2 inches??
PostPosted: Sat Jan 07, 2006 11:33 pm
Japanese Redneck
I thing the majority of the conversion owners on here have a 19x22 aluminum. I got mine mailorder from Speedway for a pretty decent price. a lot cheaper than a griffin or Howe.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Sun Jan 08, 2006 12:15 pm
Do you have to cut the lower radiator support bracket?
I only have 16 inches from the to of it to the top of the radiator core support!!
PostPosted: Sun Jan 08, 2006 5:27 pm
Yes that has to be cut out.The post that I just made with the pictures was deleted. :evil:
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sun Jan 08, 2006 7:43 pm
If anybody has a picture I would like to see the mod!!. Also where can I get a new feul level sending unit??
PostPosted: Sun Jan 08, 2006 9:34 pm
LUVTruck.com's Cornholio
Wait did u say you are from Idaho???
Kool. 8)
PostPosted: Mon Jan 09, 2006 10:34 am
yup, live in nampa, and work in caldwell!!
PostPosted: Mon Jan 09, 2006 12:52 pm
Sweet!!! Cool you have to come to the Idaho Meet we are having this spring... More and more people in Idaho this is awesome! 8)
PostPosted: Mon Jan 23, 2006 12:00 am
Ive got a griffin and yes made own support for the bottom end. :wink:
theres a picture of it on my web link take a look
http://bonsaint.com/luvalbum2/index.htm
more pics of my 76 406ci 4 spd posi.
PostPosted: Mon Jan 23, 2006 5:01 pm
is anybody useing a mid eightys corvette radiator!!, I'm broke and I know I can get one for $90
PostPosted: Tue Jan 24, 2006 3:23 am
Swap Specialist Mod
well heres a pic of peeroys luvs radiator. it was kinda spendy, but it shows how he mounted it.
as for a radiator, ive got a one out of a mercury sable that i could give you if your interested. i had it in my datsun v6 project and it cooled really well. its a 2 core plastic and aluminum radiator. if you want it its yours. i might even be able to get you an electric fan also.
