It is currently Mon Jun 08, 2026 10:42 am
 Post subject: Long bed 4x4
PostPosted: Wed Jan 04, 2006 9:41 pm
Has any one here converted a long bed in to 4x4. A long bed luv 4x4 would be cool
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Wed Jan 04, 2006 11:17 pm
i for one have never seen anything of that nature, but that isnt saying much lol
i think that would be kinda cool too
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Wed Jan 04, 2006 11:30 pm
Swap Specialist Mod
well the frames for the 2wd and 4wds are different. on athe 4wd the bottom control arm mounts in a differnt place then the 2wd. so it would be rally hard to use stock luv 4x4 part to do the swap. now you could put like a toyota solid front axle under the front end of a 2wd longbed. just hack off all the 2wd stock and figure out the steering. and probably put the rear leafs from a 4x4 luv under the back.
its could be done.
PostPosted: Thu Jan 05, 2006 12:28 am
all things are possible given enough beer and tools.... 8O
PostPosted: Thu Jan 05, 2006 11:13 am
The longer the frame the less ground clearance for going over hills. If I have to explain that then keep your LUV on the asphalt.
