It is currently Sat Feb 07, 2026 7:38 pm
 Post subject: LUV DUALLY?
PostPosted: Sun Jan 01, 2006 8:42 pm
Are there any? give me any info you got, cause i'm fixen to make the bagged luv a dually. be nice to have fenders that fit, but i will make them myself if i have too.
Thanks
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Sun Jan 01, 2006 11:08 pm
you can get these thru jcwhitney
wheel adapter
http://www.jcwhitney.com/autoparts/Prod ... 42/c-10101
and fenders
http://www.jcwhitney.com/autoparts/Prod ... 92/c-10101
seems kinda pricy but a slammed bagged dually LUV would look sweet IMO
PostPosted: Sun Jan 01, 2006 11:46 pm
Swap Specialist Mod
wow, those adapters look pretty cheesy. and for almost 400 bux?!?! i dunno
PostPosted: Sun Jan 01, 2006 11:51 pm
if was gonna use the fenders off of a '73-'87 full-size chevy stepside, they are metal and the body lines match good. if yall know where i can find those let me know.
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Sun Jan 01, 2006 11:54 pm
stupid question! so, there has never been a luv dually produced from the factory?
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Mon Jan 02, 2006 12:04 am
idea i could use the fenders from a luv stepside bed, duh! anybody got some?
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Mon Jan 02, 2006 12:07 am
i don't right now ,but someone here does don't remember the name . he is doing a stepside on a toyota frame i think
PostPosted: Mon Jan 02, 2006 12:13 am
"feeling the luv" is doing the luv onto a 'yota frame
PostPosted: Mon Jan 02, 2006 12:30 am
hay i forgot but if you don't want his style i will have these in about 6/7 months when i change my sons bed to the newer stepside like mine
PostPosted: Mon Jan 02, 2006 9:01 am
I know of a 78 flat/ stake bed LUV with no engine. It is a dually, all original I guess. I need to take a pic and post it when I get by there.
PostPosted: Mon Jan 02, 2006 7:27 pm
The LUV never had a dual wheel rear from the factory, though you could get a LUV stakebed model from the factory, but it just had a regular pickup axle in the rear. Toyota and Nissan had dually trucks available from the factory, Toyota starting in the late 70's and Nissan in the early 80's. rondog, the most important picture you could take of the 78 dually you saw would be a picture of the rear axle. It will tell if someone just made the truck a dually themselves. I wanted to ask about the stepside LUVs, did they come from the factory with stepside beds in the 70's? Really I just need a quick history lessen on the LUV stepside truck, as I don't really know anything about them. ctmandu, what kind of rims/what size are those on the rear of the LUV stepside in the pic you posted? They are nice looking rims, would you need wheel spacers to run them up front?
PostPosted: Mon Jan 02, 2006 10:52 pm
i have a 72 luv dually. im sure its not factory but its looks like it. im getting ready to tub the frame cause right now a 15" wide tire will barely fit and just incase in the future i wanna go bigger i can without chopping up the bed and mess up the paint. When i bought it it had a dually axle on it.
PostPosted: Tue Jan 03, 2006 6:40 pm
Does the dually axle in your truck have a bud wheel setup like full-size 1 ton trucks? There should be 4 rims in total, two rims mounted on each side of the rear end. In a bud wheel system the rims are mounted where the lug bolt holes line up when you face the rims together inside out from each other, kinda like this if you can imagine the symbol ">" and "<" being a rim. Looks like this, ><--[ ]-->< and it is considered the true dually setup. Now a fake setup would be the dually adapters JCWhitney sells, installed on a truck they would look like this, >>--[ ]--<< In that case you are just extending out a hub on your factory 1/2 ton pickup rear end to install a regular 1/2 ton pickup wheel in front of another 1/2 ton pickup wheel. Going the JCWhitney route would still allow you to have a dual wheel rear, higher your payload capacity, but still isn't as strong as the popular bud wheel setup. Hope it's not overly confusing.
PostPosted: Fri Jan 06, 2006 11:01 pm
Here's one its for sale too.
http://www.craigslist.org/eby/car/122688993.html
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Jan 06, 2006 11:23 pm
That truck looks like it drove through Pep Boys with a magnet on it.
PostPosted: Fri Jan 06, 2006 11:25 pm
That sums it up perfect!! 8)
PostPosted: Sat Jan 07, 2006 12:04 am
Here is a flatbed dually for sale in my area:
http://portland.craigslist.org/car/123180428.html
Not many good pictures of the dually setup, but it might give you some ideas.
PostPosted: Sat Jan 07, 2006 12:06 am
i saw that, was going to post but never did
PostPosted: Mon Jan 09, 2006 4:11 pm
I finally took the camera and went by there today. It looks like I forgot to do so for too long. It's not there any more. Sorry guys.
 Post subject: dually
PostPosted: Mon Feb 20, 2006 5:25 pm
im pretty sure mine came stock from the factory a flatbed dually... its an 81 dualy flatbed chevy luv, i also recomend putting a webber on your luv... you cant go wrong with those.
