It is currently Fri Jun 12, 2026 10:39 pm
 Post subject: Derek's truck
PostPosted: Tue Feb 18, 2003 2:35 pm
Hey just wanted to let you guys know the deed has been done (come on now no hate mail!!!!) Hehe! Yep I sold my 75 to a guy named Dan Frietas in San Jose, Ca, so if you see a yellow 75 around there that's probably it! Dan took delivery of it on the 8th, and last I heard he lowered it. I should be talking with him soon about getting the wheels off it (he doesn't like the pizza cutters on the front) so he can make it more of a road racer truck. When I can get the time I will post the story of my two day engine/tranny thrash/swap with pictures (boy was that fun!) and I learned some really cool smog tips for us califonians I thought might be nice to know. Type at ya later!
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
PostPosted: Tue Feb 18, 2003 8:18 pm
doh.. Hate to see one get dropped, :( but me i like the 4x4's 8O
Well, I loved to here about that smog stuff you got to share, California can be a pain in the arse about it...
We all are hoping you got you eyes on something... We want pictures too..
PostPosted: Tue Feb 18, 2003 8:37 pm
farewell brother... :cry:
PostPosted: Wed Feb 19, 2003 12:28 pm
Farewell??? I'm not going anywhere... I may not be a LUV owner, but hell a chevy is a chevy, hehe (did I say that?)
Anyway - Well I am a bit aprehensive about my smog secret, but it worked so here goes... My truck as you might know is a 75, V8, a BAR label vehicle, california blah blah blah.. Well anyway every time I took it to get smogged it is ALWAYS a big hassle, the CA spec for my 75 is 250 ppm (parts per million) on the HC (hydracarbons) for the V8, well the first three visits to the smog place it eventually passed with a 200-250 range on the HC at idle, at high speed it never had a problem passing but always the idle was high. Well last year it passed with 193 after lots of tuning and tweaking. This year (when I sold it) I had to get it smoged and did a little research and discovered a way to significantly reduce the HC.
Well I tried it, and after a little tweak on the idle mixture it passed with 50 ppm on the HC level at idle, a record low for my truck! You tell me if it works...
ok now the secret is a 10 to one mixture of unleaded pump gas, and one part denatured alcohol. I know it sounds real funky - but man it worked, I have paperwork to prove it. Now just dumping in a gallon of denatured alcohol is not going to make the truck pass, when the alcohol is added to the mix it actualy leans the mixture so much the motor will misfire and run so bad passing the smog test would be a joke. Once the mixture is added drive the truck about 15 minutes to get it mixed and in the float bowl, this will also clean out the motor big time! once you have done this you will need to richen the idle mixture quite a bit, I had to back out the mixture screws on my quadrajet about three turns to fatten it back up, and I don't think you have to worry about making it too rich, if it goes too rich the CO will go up over the limit, but just lean it back out and it should be ok. I used five gallons of unleaded and .5 gal's of alcohol (I wanted to get the mix out before the buyer took delivery) and this worked quite well. So there you have it... if you don't believe me feel free to email me, there are some green peace folks that think this is a hoax, well I know first hand this is not the case. Total cost was about 9.00 for a gal of denatured alcohol.
You may ask is this legal? Well I have no idea, but the smog tech guys didn't say anything, but I am sure they knew something was up when it passed with 50 ppm at idle.
Keep in mind this will not help you if you don't have the smog equipment on the motor, they still do the visual crap, this is ONLY to help reduce HC from the tailpipe..
PostPosted: Wed Feb 19, 2003 12:30 pm
Ooops, sorry I forgot to login... duhh - anyway let me know what ya think
oh and you can see the new ride at: http://63chevy2.netfirms.com
I need to update the pictures (it has come a long way) but you can get an idea
63 Nova
74 Camaro
PostPosted: Wed Feb 19, 2003 6:13 pm
i`ve done it in the past but i used rubbing alcohol and it worked just fine. i`ve been told methanol works good also and works as an octane booster but they said not to mix the methanol over 3% hey good luck on that little duece of yours.later :twisted:
PostPosted: Wed Feb 19, 2003 6:27 pm
ok i guess your still cool... :wink:
Wait of course your cool you helped bring us this site, just kinda sadening to see a luv go is all...
PostPosted: Wed Feb 19, 2003 6:31 pm
I guess any type of alcohol would work, don't know - but I know the truck had a nasty hangover the following day, LOL!
63 Nova
74 Camaro
PostPosted: Thu Feb 20, 2003 10:18 pm
as long as your truck is 21 or older its ok :wink:
PostPosted: Thu Feb 20, 2003 10:37 pm
mine is gonna fall off the wagon and get an alcohol carb :twisted:
Users browsing this forum: Google [Bot] and 28 guests
