| lives at LUVTruck.com |
Joined: Tue Jul 02, 2002 4:21 pm Posts: 252 Location: Florence, AZ
Hi, congrats on a great truck. I can give you the torque numbers as I have the 1982 LUV workshop manual. Here are the specifications for which you asked:
Intake and exhaust (cold): 0.40 mm (0.016 in)
Intake and exhaust (hot): 0.37 mm (0.015 in)
Intake valves open at 16 degrees (BTDC)
close at 54 degrees (ABDC)
Exhaust valves open at 56 degrees (BBDC)
close at 14 degrees (ATDC)
You have to tighten cylinder head bolts in 2 steps in sequence.
1st: (40-47) ft. lbs
2nd (new bolt): (54-61) ft. lbs
(used bolt): (61-69) ft. lbs
Hope this helps you out and hope the truck runs good for you. Long live diesel!
