It is currently Tue Jun 30, 2026 8:11 am
PostPosted: Sat Dec 10, 2005 3:08 pm
Hi Im a bit new here and already know Im looking to replace the stock carb with a weber. Ive heard of people finding the 32/36 and adapters at the yards, but what cars/trucks do you look for to see if they have this carb? Is it stock on some cars/trucks? Thanks
PostPosted: Sat Dec 10, 2005 4:08 pm
Swap Specialist Mod
i just got weber adapter from the junyard for my pup. i found mine on a dodge d50. its has a little thing that sticks off the side of the bottom plate that bolted to the dodge intale, but now i just cut ot off.
but look for datsuns and other small imported trucks. your bound to find one.
PostPosted: Sat Dec 10, 2005 4:17 pm
sweet. Will all 32/36 fit and work with an adapter?
PostPosted: Sat Dec 10, 2005 11:16 pm
Swap Specialist Mod
yes it will. thats what im gonna be using.
PostPosted: Sun Dec 11, 2005 3:02 am
The only issue that could come up would be if the 32/36 was jetted to big for the LUV motor, most of them were sold for motors around the same size though. Jets are also not too much and very easy to change out if you find you're running too rich.
