It is currently Mon Jun 15, 2026 2:43 am
 Post subject: 82 Luv 82 S10
PostPosted: Tue Nov 22, 2005 11:16 pm
The last year they made luvs where in 82 and the first year they made S10s was in 82. So wouldn't allot of stuff be the same except the motor and a few other small things. I f you guys could fill me in on some info I would be grateful
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Tue Nov 22, 2005 11:44 pm
Swap Specialist Mod
nope. no parts on the s10 body and the luv body will interchange. the luv and the s10 are 2 completely different trucks. the luv was built by izusu and the s10 was built by chevrolet. in 82 they did share the same motor though. i think that chevy opahse out the 1.9 for the 2.5 chevy iron duke in like 84.
PostPosted: Wed Nov 23, 2005 12:09 am
was the motor the only thing interchangeable
79 4x4 1.8 liter
PostPosted: Wed Nov 23, 2005 12:52 am
Swap Specialist Mod
yep. im pretty sure.
PostPosted: Wed Nov 23, 2005 9:57 pm
Don't forget the rear end's! :)
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Nov 24, 2005 12:19 pm
Everything except the engine and tranny in SOME cases is unique between the trucks. The rear aend can be swapped becouse the springs are the same width and they are both spring under axle mounting style. S10s ran Isuzu 1.9L and 2.2Ls for the first few years and behind those engines were Isuzu 4speeds.
PostPosted: Thu Nov 24, 2005 1:01 pm
so really the first S10 years were half luv
79 4x4 1.8 liter
PostPosted: Thu Nov 24, 2005 6:34 pm
Not realy, if you talking about just the engine and trans in some cases then yes i guess you could say that. For the early years i think the engine options were 1.9L Isuzu 2.2L Isuzu deisel and a 2.8L GM. Trannies would have probly been a Borg Warner T5 behind the 2.8L or a Turbo Hydramatic 200r4 (maybe 700r4) and then Isuzu MA4 behind the 1.9L and the 2.2L. But this is speculation becouse i am no S-10 expert. I can just talk from my arse realy well(a Canadian trait you know :wink: ).
