It is currently Sun Feb 01, 2026 3:44 pm
PostPosted: Wed Nov 02, 2005 12:36 am
To me this sounds pretty off the wall but one of my friends was telling me about a golf cart company that does or did use ford 9 inch rear ends that are 26 inches wide from axle flange to axle flange. He said he couldnt remember the name of the company but he also said there was another company building golf carts that used a chrysler 8 3/4 rear end. I havent researched it yet but Im kind of curious about it. does anyone know anything about this?
PostPosted: Wed Nov 02, 2005 2:00 am
One of the guys I work with, has a golf cart with a 9inch under it. I will ask him what kind it is.
PostPosted: Wed Nov 02, 2005 3:46 am
Swap Specialist Mod
a golf cart with a ford 9 inch rearend?? im not sure i understand the reasoning behind that one 8O
PostPosted: Wed Nov 02, 2005 4:05 am
I don't either, but they have em 8O
PostPosted: Wed Nov 02, 2005 8:31 am
That would be cool if you could find out what ind of cart has the 9 inch.
PostPosted: Wed Nov 02, 2005 12:46 pm
This is true. But understand the axel's and gears are not up to par for the V-8 stuff. Also, my 9 inch is 30.5 inches from flange to flange and running 17 inch outside to outside frame I barely had enough room to install the ladder bar's. The axels in the carts are 4 lug so you will need axels, carrier gears brgs and such. Not really a way to save money in my own opinion.
PostPosted: Wed Nov 02, 2005 4:50 pm
Currie. They started building 9" rears for golf carts, and that grew into their current business. Not sure what all brands they were in though...
Check here Currie for a history of the company...
Resident lurker
PostPosted: Wed Nov 02, 2005 7:50 pm
I just heard about the 9 inch in the carts through a friend of mine I didnt even believe him when he told me so I was just curious is all. sounds like it would be more trouble than its worth on top of needing every thing other than a housing I heard Taylor Dunn golf carts weld up the filler plug and install them upside down. I figured something like the story I was told wasnt as good as it sounded anyway.
PostPosted: Fri Nov 04, 2005 4:52 pm
Japanese Redneck
I've seen Cushman carts with a 9 under them on the local college campuses. The gardners and janitors drive them around to pick up trash. some of them have 8" under them too. they are EXTREMELY narrow though. probably way too narrow for a LUV.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
