It is currently Sat May 09, 2026 8:24 am
 Post subject: electronic ignition
PostPosted: Wed Oct 26, 2005 9:54 am
I heard someone say that Mallory Unilite makes a electronic distributer for a Chevy Luv. I am curious do they make one for a 1980 model. If so where can I get one of these at. If they do not make one for the 1980 model Chevy Luv who does and where can I get one.... Jason
 Post subject: ignition
PostPosted: Wed Oct 26, 2005 12:31 pm
Got one in my 80 4X4 now. Been there for the past year or so.
http://www.centuryperformance.com/detai ... AL-4765501
PostPosted: Wed Oct 26, 2005 1:49 pm
Thanks a million. Is it electronic? Does it work very well? How hard is it to install? As far as the wiring goes on it. Can you hook a super coil to it? Sorry, I am asking so many questions. I am just so excited about finally finding out where I can get one at. Thanks again....Jason
PostPosted: Wed Oct 26, 2005 2:57 pm
You should also take a look at the article regarding later model Isuzu electronic ignition swaps in the info section of the main luvtruck.com site. If you can find a donor, the swap is pretty simple and should come in under the price of a Mallory. Here is the link:
http://www.luvtruck.com/pdf/LUVignitswap.pdf
PostPosted: Wed Oct 26, 2005 3:48 pm
You're right, XL, it's cheaper, but I've listened to failure stories of transistorized ignition since the day it came out, and I alway assumed where there's smoke there's fire.
PostPosted: Wed Oct 26, 2005 10:23 pm
Yeah, it is a cheaper way to go, but you are swapping in used parts. You could buy the parts for the swap new, but then you might as well go for a well designed kit like the mallory.
PostPosted: Wed Oct 26, 2005 10:32 pm
I've often wondered why Pertronix didn't follow thru with their conversion kit for the rest of the LUV series. I had it on a 1972 Ford F250 for 20 years and it never failed me. And the plugs lasted forever.
PostPosted: Thu Oct 27, 2005 11:30 pm
So Pertronix #1741 only fits 74-75?
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
 Post subject: Ignition
PostPosted: Fri Oct 28, 2005 8:09 am
I thought their kits included back to 72 LUVs. You can send them your distributor and they'll make a kit to fit, but what do you drive in the meantime? Back in the late 70s I paid $20 for the one I put in my F250.
PostPosted: Fri Oct 28, 2005 12:20 pm
72-73 had the dual point setup. It seems to me though that you could put in a 74-75 single point style disti, might take some minor rewiring but it would physically fit.
It also seemed to me that the 74-75 style disti was very similar to the 76-80 one, just had a different shaft and body. I'll have to look at my books and spare parts and see. I would think if it would fit they would have listed it for the newer style motors though.
PostPosted: Fri Oct 28, 2005 1:35 pm
OOPS! I forgot about the dual points. Maybe Pertronix thought it would be to much of a hassle to make a kit for that distributor. I would've bought a kit for my 80 4X4 in an instant if it would've been available.
